Results 51 to 75 of 99
V-strom build
  1. #51
    Re: V-strom build
    You are doing all this for under a grand?
    Well then, carry on.
    Lifer jasnmar's Avatar
    Mar 2012
    Chichester, NH
    Re: V-strom build
    I *think* you've answered this elsewhere Randy, but who are you using for a machine shop?
    Re: V-strom build
    custom fab stuff has been done at B&B Fabricating here in Farmington and dealer installation at Rochester Motorsports
  4. #54
    Re: V-strom build
    I dropped my stator side cover off at KJE Automotive in Rochester a few days ago to drill the stator bolt holes and tap them all the way thru
  5. #55
    Re: V-strom build
    Significant progress, the external auxiliary alternator is mechanically installed, still have to fabricate an auxiliary battery box and do the wiring
    V-strom build-img_1286-jpgV-strom build-img_1284-jpgV-strom build-img_1283-jpgV-strom build-img_1282-jpg
  6. #56
    Re: V-strom build
    Alternator is a Powermaster 8182 75 amp rated for up to 20,000 rpm, between the stock alternator and the auxiliary alternator, I will have 108 amps on tap
    Powermaster Performance
  7. #57
    Re: V-strom build
    What ratio are you driving this at (since it doesn't come with a pulley...)? I see most ratings at 6K RPM as the industry standard. I notice the part #8182 has 7A at "idle" and 75 A at max rpm, vs. the 8162 at 30 A idle and 55A max respectively. If they're rating it at 13.5V, you're looking at 1458 watts at peak speed? This seems odd since you're into insulation, not heated gear.
  8. #58
    Re: V-strom build
    I use insulation for the coldest weather where I only ride solo (25°f and colder), electricity for above and maybe 2up
    pulley ratio is 1.5:1, the guy I bought it from did a lot of experimentation with pulley ratio and load testing at various rpm, initially he was using a different alternator but it couldn't handle the high rpm of a bike, hence the reason for the 8182, his testing showed that it puts out over 50 amps at V-strom 1k cruising rpms.he ran this setup for nearly 2 years until he returned his Vee to stock and sold the bike. then offered me the setup for $200
  9. #59
    Re: V-strom build
    Looks like my auxiliary battery will be a DS42B24R (Prius) , I will have to notch my inner fender for clearance
    leaning toward a yellow top optima, designed for both starting and deep cycle, 450CCA, with the extra power, I will easily have enuf for 2up heat,100watt eurobeam driving lamp, 55watt fog lamp (both Hella 4000s) a set of low mounted leds, heated seat (rider and pillion) and a 200 watt inverter, as well as gps,radar & autocom
  10. #60
    Lifer Tekime's Avatar
    Mar 2016
    Falmouth, ME
    Re: V-strom build
    Awesome project. Looks super clean too. So in the summer you can power a railgun which will be nice.
    05GSXR75005SV65090DR350
  11. #61
    Lifer Stromper's Avatar
    Eastern Ct
    Re: V-strom build
    Randy... missed you at the peeps all the usual suspects were there
    Take a look at a marine battery if they are small enough, they take lots of physical and electrical abuse
    The calculus of hate
  12. #62
    Re: V-strom build
    marine batteries are not rated for cold starts, I considered them, not many people go boating when it's -30°
  13. #63
    Re: V-strom build
    just ordered the battery, found it for $123.74, over $100 off list price of $225.99
  14. #64
    Re: V-strom build
    now I get to work on the box, I will make a cardboard mock-up to give to my local fab shop, end result will be tight fitting box about 5" higher than in the photo
    V-strom build-img_2115-jpg
  15. #65
    Re: V-strom build
    ready to make progress again, but am rethinking my battery location
    it would be much easier to mount the battery and all the components in a NEMA 4 box on my luggage rack, it would be more easily accessible, and the Optima battery is an AGM so it don't need to be mounted vertical, the downside is higher center of gravity, the 23 lb battery will be nearly a foot higher, and behind the rear axle
    a custom battery box would be much more complicated, and cut into the underside of the tail with barely any clearance between the chain guard at full compression of the suspension
  16. #66
    Eastern Ct
    Re: V-strom build
    Brave enough for lithium
    search ebay for the box also Nema 12 would be fine too
  17. #67
    Re: V-strom build
    lithium was not even a consideration, cold weather reliability was my #1 consideration when choosing a battery, and Li is not there yet
    NEMA 12 is primarily an indoor enclosure, not rated for water tightness that the NEMA 4 is
  18. #68
    Re: V-strom build
    been looking at this enclosure
  19. #69
    Re: V-strom build
    4 years later......... the build was put on hold while I was getting my seizure disorder under control. haven't even registered the bike in 2 years. Today, it went off to my dealer for service & inspection, I will get it registered tomorrow, so they can put a sticker on it.
    Then I'm back to the build, first thing is the battery box, then an auxiliary wire harness, and hook it all up.
    after that, next on list is a Russell Day Long Saddle
    and somewhere in future is an expanded fuel tank
  20. #70
    Re: V-strom build
    Attaboy!
  21. #71
    Re: V-strom build
    I learned today, I may have a rusty fuel tank issue
  22. #72
    Re: V-strom build
    V-strom build-img_2132-1-jpg
  23. #73
    Re: V-strom build
    Let me know if/when you want a hand with that so we can make sure the entire tank gets coated proper!
  24. #74
    Eastern Ct
    Re: V-strom build
    Randy Strommer are have an intimate Peep show up at Cupsuptic/Rangely
    Poorly attended all the Canucks are some where else in Northern Quebec
  25. #75
    Re: V-strom build
    As beet would say: "ta fuck?"
  1. New V Strom XT or ???
    By TheJRM in forum General Bike Related
    Last Post: 09-05-15, 09:06 PM
  2. For Sale - Motorcycles | 2012 V-Strom 650 ABS
    By No Quarter in forum For Sale
    Last Post: 08-30-14, 09:07 PM
  3. '06 Suzuki V-strom 650
    By Intrepidse17 in forum For Sale
    Last Post: 10-25-13, 06:16 AM
  4. My V-strom has cancer
    Last Post: 05-08-12, 07:48 PM
  5. V-Strom Yaweh provides
    Last Post: 10-22-04, 02:08 PM
