Results 1 to 16 of 16
newbie bolt question
    WMC original sdog30's Avatar
    Burgy
    Read the rules, I'm safety wiring:
    -caliper bolts (front and rear)
    -front axle stay bolts (the four in the front of the fork at the bottom)
    -oil plug, fill, dipstick
    -oil filter
    Am I missing anything. This is on an 05 r6. Pretty sure I'm supposed to do the header bolts, but thy're nuts that thread onto stems that come off the block, so not sure how I could do that. Also, my rear axle bolt is solid with no cotter pin, does this need to be wired?
    LRRS/CCS #66
    Re: newbie bolt question
    Radiator cap, water pump drain bolt...can't think of any others. Here is how I did my R6 axle nut.
    And you also do the header nuts the same way.
    Senior Member Slowpoke387's Avatar
    Enfield, CT
    rear axle nut needs to be done. I usually start those by drilling straight like im going right thru, just enough to make a divit. Then you can angle it diagonally thru. Front axle main bolt, and outer exhaust bolts too. Those last ones are a pia. Water pump drain bolt also.
    LRRS #387
    Burgy
    Thanks guys.
    5/16th drill bit?
    LRRS/CCS #66
    Wirelessly posted
    1/16. Not 5/16. Lol. That's some BIG safety wire
    Get Weird! maxim_X's Avatar
    Fairhaven, Ma
    Buy more than one drill bit. In fact buy about 5.
    LRRS EX 151 AMSOIL
    JCBernier -- You-tube
    Wirelessly posted
    I never thought of using electric fence...hmmmm.
    The water pump drain bolt is often forgotten and most riders don't have it done.
    You need the inner and outter header bolts wired.
    The radiator cap.
    Calipers.
    Front & rear axles.
    Front axle pinch bolts.
    Front and rear caliper bolts.
    Oil fill cap
    Oil drain boot.
    Many wire the brake pad pins also.
    High maintenance priss
    Central MA
    Thanks guys.
    5/16th drill bit?
    When we spoke I accidentally said 5/16. I meant 5/64. I break less bits using a 5/64 vs a 1/16.
    Large member Larry's Avatar
    Nov 2010
    Limington maine
    I didn't even try to drill the header nuts because they tend to harden a bit from heat cycles. Just pick up some new nuts for the studs and pre-drill them and put them on IN ADDITION TO the existing nuts and then run safety wire.
    Burgy
    Thanks for the input guys.
    Is the water pump drain bolt the big bolt on the front of the engine block, right behind the header? It's on a 4 or 5 inch round part with hoses going to it.
    LRRS/CCS #66
    Lifer union's Avatar
    Blackstone, MA
    Water pump bolts on the Yamahas should be on the right side of engine. On my R6 its a 8mm bolt with a crush washer on it. Its the bottom bolt on the case where the two hoses come in.
    As for the header bolts. You can "cheat" a little. Just do the two outside pipes. Wrap wire around the inside stud close to the bolt and bring it around to the outside stud. The nuts wont be wired but with the wire on the stud they wont go anywhere.
    Also dont forget the bolt that holds the exhaust can on. Im assuming youre getting race prepped? Doing all this for a trackday is overkill.
    James
    Burgy
    WHAT?!?!?
    My friend told me these were the requirements for Tony's day?
    LRRS/CCS #66
    Burgy
    Just kidding.
    Yeah I'm race prepping for this weekend. Trying to be proactive so there are no surprises at tech Saturday morning. Although it looks like I will be swapping brake lines Thursday night in the gargage. Got a little last minute...right?
    LRRS/CCS #66
    Burgy
    Thanks again everyone. I pulled them all, now I'm headed down to the shop.
    LRRS/CCS #66
    Blackstone, MA
    Just kidding.
    Brake lines are easy if you know the trick Ill be at the track Friday afternoon. Take advantage of the free garage if you already dont have one for the weekend. Me and PK are next to it so we are there to help out.
    James
  1. '06 SV650S Noob bolt question
    By DroFiveOh in forum Bike Maintenance
    Last Post: 06-20-12, 02:20 PM
  2. Newbie Question RE: SV650
    By DroFiveOh in forum General Bike Related
    Last Post: 05-07-12, 08:04 AM
  3. Newbie question
    By sdog30 in forum Pit Area
    Last Post: 05-01-12, 09:14 AM
  4. Another newbie question
    By j4eric in forum General Bike Related
    Last Post: 11-10-10, 11:15 PM
  5. Newbie Exhaust Question
    By bryco13 in forum Bike Maintenance
    Last Post: 08-28-08, 09:18 PM
