Wirelessly posted (Tilt: HTC-ST7377/1.59.502.3 (67150) Opera/9.50 (Windows NT 5.1; U; en))
My bike vibrates mostly through the clipons, it might be the only place i feel it, not sure. It started doing this after my lowside at bomo.
It vibrates when:
In neutral moving from 2k rpms and up.
In neutral not moving(sitting on kickstand) from 2k rpms and up.
In any gear moving 2k rpms and up.
In gear with clutch in moving and not moving 2K rpms and up
It doesnt vibrate:
While moving with the clutch in and no gas givin.
When its off.
I am going to change the oil and take the plastics off and check the motor mounts tomorrow. If you are unfamiliar with my lowside, it was when i was fully leaned over and wasnt much of a shock to the woodcraft slider, minimal damage occured to the bike/plastic, the right side clipon had rotated a little bit due to sliding on the ground. Bike is a 2k9 gixxer 750 with 13k miles on it.
Any Ideas?
