Results 1 to 10 of 10
loud pop noise under hard acceleration
    Member dj 96yzf750's Avatar
    springfield mass
    when i accelerate hard while in 1st or 2cnd gear it sounds like the chain is slipping but i check both the front and rear sprockets and they are not worn at all and chain is not lose at all either, any idea what could be the problem?
    Re: loud pop noise under hard acceleration
    How many miles on the chain? Mine started making almost clunky noises when it started to go, but you could tell it was the chain. If you had the bike on a stand and spun the rear tire you would see the kinks starting. Something to check..
    Raymond NH
    Might have a broken engine mounting bolt.
    springfield mass
    well the chain is off an fzr my bikes a yzf,had to add another maser link so it can fit on mine
    Lifer DuncanMoto's Avatar
    Make sure your rear axle bolt and adjusters are tightened properly.
    Just Registered drop's Avatar
    Bradford, MA
    my friend's bike was doing something similar, might be your problem as well. the master link had worn and stretched slightly, causing only that link to catch a tooth and hop off the rear sprocket a little. the chain tension as a whole was still within spec, only the individual link had stretched.
    - Jamie
    2009 K 1300 S
    springfield mass
    sterlinks on my chain i can only wait and see whn the new chain comes in on the second
    springfield mass
    Lifer TIMMYDUCK's Avatar
    Feb 2003
    The 14th State Vermont
    Take your front sprocket cover off and clean, clean , clean.
    You are goig to find a large amount of gummy black stuff with pebbles and other assorted grimey things.
    So use plenty of solvents and clean up your drive chain cover and such.
    TIMMYDUCK
    Central MA
    This could quite possibly be something more serious than chain/sprocket problems. You may be looking at transmission gear/dog/engagement problems.
  1. A bike issue. Loud noise.
    By Rambunctous in forum Bike Maintenance
    Last Post: 10-13-13, 03:33 PM
  2. Hard acceleration
    By SEVENSGT in forum General Bike Related
    Last Post: 10-27-04, 01:01 PM
  3. Loud pipes? No... Loud HORNS!!
    By PatSV650 in forum General Bike Related
    Last Post: 09-08-04, 05:20 PM
