Page 2 of 2 FirstFirst 1 2
Results 26 to 27 of 27
Rusty coolant system
    Re: Rusty coolant system
    I can flush it clear pretty easily, but then after running it for the year, itll be like loose baby shit brown regardless. So its there.
    Also, I don't know what/how the previous owner treated it, so dunno if they just ran tap water or what.
    Flush it aggressively to get any sediment out, and I don't mean fill, heat cycle, dump; I mean put the hose to it with the drain pulled and run some FLOW though it. Next, optionally, run a treatment option of your choice, dilute vinegar and time, commercial radiator flush, CLR if you wanna go REALLY aggressive, etc. Once done, put distilled water in it, use a track safe/legal additive package like Cool-Aide/etc as a corrosion inhibitor, and change the water more frequently going forward.
    I mean put the hose to it...
    Not a good idea as it will only continue the issue. You don't want any tap water going into a cooling system, ever.
    Yes, the distilled water will dilute the tap water but the iron (and other minerals) are still present in the tap water regardless of dilution. There will still be a reaction within the cooling system.
  1. Rusty gas tank interior
    By BMFR6 in forum Bike Maintenance
    Last Post: 09-20-21, 09:53 AM
  2. 1st annual Rusty Ride...
    By Sheppo in forum Rides & Events
    Last Post: 09-11-13, 10:58 AM
  3. Rusty Cycle Cafe
    By clutch in forum General Bike Related
    Last Post: 06-23-13, 01:22 AM
  4. Rusty Chain
    Last Post: 03-19-11, 10:24 PM
  5. Rusty Razor Blades
    By scottieducati in forum Wanted
    Last Post: 01-06-10, 05:40 PM
