Give it a good spray with WD-40, then wipe said rust off. Most will come off with a rag. Then keep that thing goobed up with a chain wax.
Kerosene
If it's non O ring, wire brush it, O'ring, soak it in kerosene but that wont remove the rust, only the crud! Try a brass wire brush at 90 degrees to each side plate so you dont hit the O rings if it really bothers you and you can be bothered!! (dont forget to clean and lube afterwards if using an wire brush)
Surface rust?
Proper lube and....
Ride more. Worry less.
Lots of stuntn'... Just saying.
-Alex
Just looked at Miami on google maps cause I thought there might not be a bone straight road somewhere. LOL wow. That and knowing the Everglades is a swamp that big kinda weirds me out.
-Alex
The front straight at loudon would be considered a turn in florida.
-Brian
15 S-Works Venge
Had no choice, nowhere indoors to keep it. Finally got a place, need to clean it up.
Cept its a criminal charge to pull up a power wheelie out of a uturn, let alone a good one.
When my GoPro gets here Ill video one of the 2 roads Ive seen in Florida with a curvy road sign. Youre gonna laugh. Then cry for me.
The only road with turns are the long sweeps entering palmeto prkwy, there is a road up in ft laud that runs north south and east west, that has a turn in it , unless they straightened it out .
Beat It Like A Rented Mule !!
Legend in my own mind
Chain wax, what is this wax? Wax? Carnuba?
1985 Cagiva 650 Alazzurra, 1992 VFR 750
Speed bumps & boobies count?
Dear Richie,
Please come home.
Love,
-butcher bergs
