So the SV I have shifts fine. Problem is, there really is no spring pressure on the shift lever. It's to the point that if my toe is touching the lever at all, I won't be able to make the second shift since it hasn't returned to the center.
Is it possible for the shifter detent spring fell off or broke?
Never opened up the side of the SV case. Don't mind doing so, but I don't want to split the cases.
