Page 4 of 5 FirstFirst 12345 LastLast
Results 76 to 100 of 112
2003 sv650 parts & advice :-)
  1. #76
    Jul 2006
    Albany, NY
    Re: 2003 sv650 parts & advice :-)
    does the radiator leak? I raced mine for parts of 3 years with it practically bent around the frame, it finally gave out rubbing on the fairing. I researched sv rider and Delkovic was supposed to come out with a gen 2 aftermarket radiator for around $150, but alas I needed one quick and paid top dollar for a used one on ebay.If you need calipers or the whole brake system I have it cheap. I bought the bike salvage with 40 miles on it and changed out a lot of stock parts that are perfect, let me know if you need anything
    I'm good on brakes and no the radiator doesn't leak. Pete I'll be giving you a call about the penske stuff.
    Feb 2004
    Bellingham, MA
    I have call forwarding on if you want to call today, or we can talk Monday
  4. #79
    I'd rank Elka below Penske... though I don't have much of any personal experience with either. All my bikes came pre-equipped with Ohlins shocks, courtesy of a previous owner.
    Depends on the shock.
    I have an Ohlins double on my SV and a Penske triple on my 1000RR. I like the additional compression adjustments on the triple.
    Both shocks are super-high quality.
  5. #80
    Just spotted a Penske on the STT forums. He had forks too.
  6. #81
    that guy darkduc7's Avatar
    Apr 2010
    Georgia, VT
    i want!
    EDIT: its for a 2nd gen 650, crap. plus its setup for 160, too light for my ass.
    CCS/LRRS EX #226
    LOW DOWN RACING
    Current stable:
    2008 hyper 1100
    2007 crf450r
    2009 yz450f
    2008 sikk mx 125 minimoto
  7. #82
    Swapping springs for rider wt isnt expensive.
  8. #83
    Which?
    Which what? Which forum? Sportbike trackbike, for sale section.
  10. #85
    Apr 2010
    Georgia, VT
    wouldnt i have to have it revalved as well, along with the stiffer spring?
    CCS/LRRS EX #226
    LOW DOWN RACING
    Current stable:
    2008 hyper 1100
    2007 crf450r
    2009 yz450f
  11. #86
    Feb 2004
    Bellingham, MA
    Quote Originally Posted by darkduc7 View Post
    And make it longer, Too much in parts, around $560 parts and labor for a revalve, spring, shaft and body.
  12. #87
    But that's to make it work for the other gen SV, right? You wouldn't have to do all that if you're just changing for rider weight, correct?
  13. #88
    Not a cool kid Charlief's Avatar
    Ipswich
    Not to get off topic but I looked for months for a used penske for my gen1. I found that they either weren't sprung for my weight or needed a rebuild. Adding to that....they were not bargains to begin with.
    In the end I decided that used was not the way to go.... I saved enough money on other used pieces(plastics, master, clipons,etc) that spending for a new shock was worth it.
    I called GMD and had my Penske days later. To me it was worth it. Just my .02.
    Charlie
    Me no likey crash
  14. #89
    Im just guessing that a spring change is all that's needed for rider wt. but Idk for sure.
    On another note, some guy on here is parting out his srad gsxr, including the front end....just saying....
  15. #90
    Quote Originally Posted by Charlief View Post
    Charlie
    AWbsolutely. I did all the suspension upgrades on my DL650 [street].
    When I bought my SV650S I made an appointment with GMD before I'd even picked up the bike. So first time I hit the track, the suspension was perfect, and the cost was very reasonable: less than what I paid on my own for the DL.
  16. #91
    Feb 2004
    Bellingham, MA
    Right, 03+ SV's have a shorter shock than the 99-02, and the valving in a Penske is flexible enough to cover the range of spring rates for most riders, 83 lb Supermodels, and Sumo wrestlers not with standing.
  17. #92
    Apr 2010
    Georgia, VT
    so, if a penske has a 425lb spring on it, you could go to a 700lb without revalving? nice
    CCS/LRRS EX #226
    LOW DOWN RACING
    Current stable:
    2008 hyper 1100
    2007 crf450r
    2009 yz450f
  18. #93
    Feb 2004
    Bellingham, MA
    No if it has a #425, you could use springs from #375 to #475. For a #700 you would need different valving.
  19. #94
    I think I'm gonna end up just buying a new one at the time my bike goes to gmd. Which by the looks of it will be around feb or so. That'll give me some time to save up a cushion to get what I want done(and done right).
    Still looking for stuff like rearsets and clipons. Preferably woodcraft stuff. Used race plastics also.
    Ipswich
    Good choice on buying new....A gen1 Penske 2 way with remote was listed on SV rider for $315. It needed a rebuild but lasted less than an hour then it was snapped up.....hell I almost bought it as a spare.
    I know you needed a gen2 but as we see...when they are listed ...they sell quickly.
    Me no likey crash
  21. #96
    Feb 2004
    Bellingham, MA
    Quote Originally Posted by Alvecchio View Post
    I have a new set of Woodcraft 41mm clip ons for $125
  22. #97
    I'll take em :-) pming you with details
    What's this I keep seeing about an r6 throttle tube. Worthwhile upgrade?
    Wirelessly posted (Samsung Lube.... Er, Glyde: BlackBerry8520/4.6.1.314 Profile/MIDP-2.0 Configuration/CLDC-1.1 VendorID/102)
    It just shortens the throw of the throttle a little. Makes a little difference and is nice to have but I wouldn't make it a priority.
  25. #100
    i've got one if you're interested. it was i think $31 or $41 (forget what the dealer charged). i never needed it, as i found out that i already had one on my bike. if you're interested in it, let me know.
  1. For Sale - Motorcycles | 2003 SV650 SUPERBIKE
    By wolfie109 in forum For Sale
    Last Post: 09-26-16, 04:21 PM
  2. 2003 SV650 SuperBike
    By daviid in forum For Sale
    Last Post: 03-27-14, 09:37 PM
  3. 2003 SV650 N - 17k miles
    By NlC0 in forum For Sale
    Last Post: 06-08-13, 11:33 AM
  4. 2003 Sv650 $3000.
    By catahoulabuldog in forum For Sale
    Last Post: 12-02-12, 09:49 PM
  5. Need advice-- 02 SV650
    By Charlief in forum General Bike Related
    Last Post: 02-06-10, 11:38 AM
