Page 1 of 2 1 2 LastLast
Results 1 to 25 of 40
Ariens Deluxe 28 Snowblower Won’t Start
    South Coast MAsshole
    Trying to get my brother in laws snow blower started...it’s an Ariens Deluxe 28 model 921037 with an AX 414 engine...from what I understand it’s been sitting for about 3 years...It had a full tank of fuel so I drained it through the carb bowl to verify I had steady fuel flow...then I put fresh fuel in with seafoam...there is no fuel filter other than the screen in the tank opening...then I pulled the spark plug and cleaned it and reattached the wire and grounded the end of the plug against the engine and pulled the cord to verify I had spark...then I pulled the carb off and ultrasonic cleaned it...reassembled everything and tried to start it with the electric start and the gas cap loose in case it was a vacuum issue and it was backfiring but will not start...any ideas?...thanks in advance
    Point37s Garage Sale Thread
    Lifer Falko's Avatar
    MoonTown
    Re: Ariens Deluxe 28 Snowblower Won’t Start
    What did you put in the ultrasonic cleaner to use as a cleaner?
    Simple green and water...looked brand new when I was done but didn’t look bad to begin with
    Lifer golden chicken's Avatar
    Attleboro, MA
    Mine will flood with the choke and then puke fuel from the muffler if I keep cranking it. I'd pull the plug and see if it's wet. Maybe drop a half teaspoon of marvel mystery oil down into the cylinder while the plug is out.
    I’ll give this a shot...thanks
    I cheat and use the electric starter, spins much faster.
    Those new carbs all seem to have plastic seats now and haven’t had much luck without replacement.
    Lifer Stromper's Avatar
    Eastern Ct
    Ether- starting fluid
    There is always the voodoo that the flywheel has sheared its key and is rotated away from proper timing
    Plug should be swapped as there is MUCH higher resistance when under compression compared to air then it carbon tracks meaning there
    is no spark in the engine
    At least turn it over with thumb over spark plug hole to check for compression
    Kick it a few times to let it know who's boss
    The calculus of hate
    I think may be the issue
    http://apache.ariens.com/manuals/B-2116.pdf
    TWINS! xrocket21's Avatar
    Central Maine
    My go-to move is to pull the plug, pour some fuel down it, then start it. It can conform if it will run or not, possibly determine if you have a fueling issue, and many times it simply gets the fuel flowing and clears out any air bubbles in the fuel lines.
    Meriden, Ct
    Its a dirty carb.
    confirm it has spark by pulling the plug, leaving it attached to the coil, holding the electrode near the block and pull the starter. If you see a flash, you have spark. Once this is done....
    go clean the carb properly
    Central Maine
    Its a dirty carb.
    he did that
    Meriden, Ct
    he did that
    the I should have stopped typing after the first sentence.
    Good catch! Good you found it in September.
    Central Maine
    i still say pouring some fuel in will help show that it is a fuel issue if it runs off that
    Lifer ZX-12R's Avatar
    Candia, NH
    The bulletin is for a different engine and you said that you do have good spark. It still sounds like a fuel issue to me. How confident are you that all the jets in the carb are properly cleaned? I'd gamble on a carburetor rebuild kit which should be $30 or less.
    Ariens Sno-thro And Lawn Mower Carburetor Repair Kit
    I'd venture that was an educated guess
    Candia, NH
    Quote Originally Posted by loudbeard
    Perhaps! I don't want him to pay extra from a dealer that likes to mark things way up.
    So I started to follow the TSB and decided to swap the spark plug from my platinum 30 sho (same engine) and give it a try and it fired right up...now it will start and run but the engine surges and backfires and it dies after a few minutes when the choke is off
    Candia, NH
    That still sounds like a fuel issue from a carb that isn't completely clean.
    my aunt just gave me a 2 year old lawnmower. it would fire then die instantly. THAT EASY. I've got spark. ITS FUEL. Tore the carb apart made sure the carb cleaner would flow thru all the ports and shot compressed air thru everything. I bolted everything up and 2nd pull it ran like champ.
    How much more evidence and statements will it take to start working on the carb? Trust me, I hate them too.
    Rebuild kits are non productive, good chance he can get a brandy new carb for $30 or less, a genuine Honda carb for a GX160 I have was $26 from a Honda dealer
    Candia, NH
    Without digging through manuals to find the exact part number, I had no luck finding the appropriate carburetor on eBay with the less than the 30 seconds I allocated to it. But yes, cheap carburetors are a thing.
    +1 ... Jack's Small Engines
    EDIT: looks like this isn't the case for this machine though... ~$30 vs ~$100 ...so i guess it depends how much you hate fiddling with carbs
    i have done the same as Randy in the past, but for more simple setups.
    Read the first post...I already pulled the carb and ultrasonic cleaned it...looked very clean to before I cleaned it...probably pull it again and do a total disassembly/cleaning but I doubt I’ll find any issues...only thing I can think of is bad rubbers letting in air causing a lean condition although I don’t see any fuel leaking...I’d rebuild before buying a new one...it’s metal and very clean so I can’t see wasting money on a brand new one...plus a new one is over $100...rebuild kit is $25
  1. For Sale - Other | New Ariens Deluxe 28 SHO
    By zxme in forum For Sale
    Last Post: 11-11-24, 05:22 PM
  2. For Sale - Other | Ariens deluxe 28 SHO snowblower
    Last Post: 08-24-22, 04:59 AM
  3. For Sale - Other | Ariens Deluxe 28 like new
    Last Post: 03-11-22, 06:54 PM
  4. For Sale - Other | Ariens Deluxe 28 SHO
    Last Post: 06-24-21, 04:35 PM
  5. For Sale - Other | Ariens Deluxe 28 Snowblower
    Last Post: 10-15-18, 07:24 PM
