Page 1 of 2 1 2 LastLast
Results 1 to 25 of 26
longshot any bee exterminators here?
    Wirelessly posted (BlackBerry8330/4.5.0.160 Profile/MIDP-2.0 Configuration/CLDC-1.1 VendorID/105)
    Looking to get rid of a big nest behind the siding of our house. I'm allergic, very alergic.
    Lifer DaSarge's Avatar
    Oct 2002
    Cape Cod
    Re: longshot any bee exterminators here?
    You should of told me when I was at your place..I would of done it.
    Didn't know then, jackass. Anyway, you,d probably shoot them individually with a .50 cal pistol for 3 days.
    Oct 2002
    Cape Cod
    AND? The job would of got done that way...Plus you'd have a more ventilated garage.
    Do you know what kind of bees they are? Wasps, hornets, yellow jackets, white faced, Honey bees??
    A local beekeeper may come get rid of them for you for free if they are honey bees. They can be trapped and moved to another hive pretty easy.
    I'm kinda in the same situation though, and mine are not honey bees. I've got a white faced hornets nest the size of a football hanging off the soffit of my basement entry at eye level. My plan (these are nasty fuckers) is to get some hornet spray, put my riding leathers on, tape my pant legs to my boots, tape my gloved to my leathers and put a helmet on and tape something on to create a seal around my neck. Yes, I'm to cheap to call an exterminator
    Go out there at night, spray the entry hole with a full can of spray, let it sit for a bit then remove the nest...and hope I don't get stung
    Lifer Evil_Weasel's Avatar
    Over the Highside
    napalm and catapult? just how attached to this house are you?
    As usual, your post displays a complete lacking in any fucking idea what you're talking about.
    Hey, at least you're consistent.
    Oct 2002
    Cape Cod
    Lighter and hairspray...Let 'em burn.
    Ense petit placidam sandman's Avatar
    sema
    Quote Originally Posted by DaSarge View Post
    starting fluid works better, with a fresh can you can get them 20' away without a problem
    jim
    "Molon labe"
    Bee Bopper works real well, this tiny aerosol can can squirt 20+ feet, bees & wasps die before they knew what hit them
    <---- R.I.P. Hauptman's Avatar
    Pepperell, MA
    If you're really allergic then yeah just have someone else spray them. The hanging nests I always mess with first. I have a scoped 1000fps pellet rifle that I plink away at the nests with before I spray them. I hate bees.
    08 SV650s = brokenz
    Mar 2004
    woonsocket ri
    WHen you go to spray them do it at night. All the bees are in the nest and they really hate to leave it so the chances of being stung are low. It's kinda stupid to burn a nest attached to a building.
    Just Registered
    Is it not obvious?
    www.bee-busters.com
    If you end up going professional...these are the professionals you want to call. They do awesome work.
    www.gpsdiscussion.com
    motorcycleaddicts.org
    Oct 2002
    Cape Cod
    You guys are thinking WAY too logical here with your bee sprays...You have to get rid of these bees in the most awesome unlogical way...Like hang a picture of richie next to the nest and they will die from laughter
    Just Registered
    Is it not obvious?
    You think teabagging the nest would work?
    Oct 2002
    Cape Cod
    Quote Originally Posted by ssg View Post
    Only if Jim does if for some reason
    who knows
    I'm not allergic but I hate getting stung, if it was a hanging nest i would be all over killing those little fuckers. i landscaped for 6 years and i have had lots of experiences with killing large nestes in bushes when we were pruning and found one. you just need like 4 -5 cans of spray... i would first hit them with this shit that foams at the mouth of the nest so the bee's comming out get stuck in the foam then douss the rest of the nest over and over till it get's soaked all the way through then 2 hours later cut and disect because the hive are WICKED COOL tolook at opened up.
    Lifer Danz19899's Avatar
    Grafton, Ma
    i had a nasty one under my deck earlier this year. probably the size of a basketball i just waited till it was night and then used 2 entire cans of the foaming stuff from 20ft away and blast them. the next morning i used my pool net to knock it down and cover it then dumped strait chlorine on it lol
    Lifer Punjistick's Avatar
    Norwell, MA
    Wirelessly posted (BB 8310: BlackBerry8310/4.5.0.161 Profile/MIDP-2.0 Configuration/CLDC-1.1 VendorID/102)
    Derek, do you know if they are honey bees? Harrison and my mom have 2 hives and sell honey. They have the suits, hats, smoker, and everything.
    Southern, NH
    Lifer Currently's Avatar
    Ooltewah, TN
    I use a vacuum cleaner ... put the end of the wand next to the entrance and duct tape the wand so it stays put. Turn the shop vac on and walk away.
    In an hour or two, they are all gone. You know you are winning when they start exiting the nest with the baby grubs in their mouths.
    If the nest is behind the siding, it is the only way to get rid of them.
    You may want to set it up at night and the next day start the vacuum and walk away.
    Never been stung cause all their attention is focused on the end of the wand.
    You can't run away cause that will take their attention from the wand to you.
    Just move very slowly.
    If loud pipes save lives, imagine what learning to ride would do.
    Ill check on what kind of bees they are.
    Winter sucks Nate Dawg's Avatar
    Providence
    I'll come kill them for you!! I'll come by tomorrow or Tues after work
    08 Ape RSV1000R
    09 Ram 1500 Black Big Horn
    10 Mini Cooper S sleeper (hers)
    Just Registered kermita's Avatar
    Mar 2007
    RI
    If they are honey bees please please please don't kill them. There is some sort of disease that are wiping them out as it is. That is not at all good for farms, orchards etc as bees do lots of good work there. Sounds like there are some people here that are, or know, beekeepers. Please take advantage of their services if the hive is indeed honey bees.
    Thank you from a backyard gardener who has learned to appreciate what honey bees do...and am lucky enough not to be allergic to them as well.
    -kim
    drz400sm
    http://farm3.static.flickr.com/2473/3532494258_79ceb54614.jpg
    Providence
    A customer had a honey bee infestation in his house. The entire front left side of his house was covered in them. They'd gotten inside between the interior and exterior wall. He said they'd been liveing there for about 4 years. We ripped down the exterior siding, and holy shit!!!! there was a hive about 15 ft high, and 8 feet long. Unfortunatly we had to destroy the bees. We searched for weeks trying to find someone who to take them away. I contacted as many bee keepers as I could and no one wanted to take the bees for free. The honey inside the walls made the biggest mess! My truck, tools and clothes were covered in honey for weeks.
    08 Ape RSV1000R
    Quote Originally Posted by kermita View Post
    One of my neighbors is a beekeeper, he has 4 hives and one of them is in his living room. One of the coolest things I've ever seen for sure. It's made of lexan and you can see everything from the bees bringing in the honey, the queen laying the larve, and the new bees hatching. A well established honey bee hive can have well over 100,000 bees in it.
    I was supposed to start my own hive this past spring but never got a chance. This winter I'm buying the hive box and ordering myself a colony of bees. For what it's worth, natural honey from your area is the best cure for allergies
  1. Longshot - Anyone going from NYST to NH, this weekend?
    By TrackRat in forum General Track Day Talk
    Last Post: 09-17-14, 08:12 AM
  2. Replies: 9
    Last Post: 11-15-13, 10:05 AM
  3. Replies: 3
    Last Post: 06-20-13, 04:45 PM
  4. Longshot but worth a try
    By xxdcmast in forum General Bike Related
    Last Post: 05-03-06, 06:42 PM
