Results 1 to 15 of 15
Best Tree Stand Ever
    [Swivel Straight Tree Stand w/Removable Water Reservoir — QVC.com
    Pricey but worth every penny.. for those of you who dislike this part of putting the tree up ,This is a god send...
    I have owned one for the past fourteen years only issue is the check valve on the water container is leaking a little..
    Re: Best Tree Stand Ever
    Took me a few minutes to figure out that it would be hard to hunt from this.
    9 Not allowed! Not allowed!
    Yes , I thought about that. To late to change the tittle.
    Lifer capitalcrew's Avatar
    Feb 2017
    Albany NY
    Oof came for hunting content lol
    Lifer 01xj's Avatar
    CT
    I read "wheel stand" and was thinking balancing, tire removal etc. Clicked the pic and it sorta made sense but was wondering why it needed to be watered.
    Lifer Tekime's Avatar
    Mar 2016
    Falmouth, ME
    Struggling hopelessly with the tree while my family sits back and laughs is kind of a hallmark of our Christmases
    05GSXR75005SV65090DR350
    Lifer Falko's Avatar
    MoonTown
    After mine fell over three times, it is now fish lined to the wall.
    Lifer jimmycapp's Avatar
    Oct 2008
    NW CT
    Had that one growing up. Works great. Now I have this one, going on two years. Stick it in, ratchet loosly, stand it up, quick release the ratchet, then ratchet it down while holding it strait. Much faster setup, and just as fast to adjust. Works great on our 14' trees.
    Best Tree Stand Ever-81wjvemcs9l-_sl1500_-jpg
    https://www.amazon.com/Krinner-Genie...mas+tree+stand
    I used to do that myself till I purchased this stand. The cats have even climbed the tree without it falling over. Watching the tree fall over because of that sinairo , although entertaining as it was, is something I would like to avoid.
    Lifer LuvDog's Avatar
    Ashland, MA
    I have this stand too. Works great. Takes just a couple of minutes to set up the tree. And holds a bunch of water
    2003 ZX7R
    1995 916
    MoonTown
    My issue is my stand only holds the tree at the top. So if the tree is soft and manages to shift on the bolts holding it, the bottom easily moves to a side and then topples over. The bolts only serve as a pivot point. I think this summer I'm going to grab some steel from the shop and whip something up, that will probably weight 85#, look like shit, leak water, and get rusty. But that's how I roll.
    you could always go this root! YouTube
    Lifer BSR6's Avatar
    I have this one which uses eight bolts to hold the tree. If you look closely the bolts are L shaped at the end so you can adjust them with you fingers. I swapped them out with standard 1/2 hex heads and use a speed handle with a half inch socket to adjust them.
    I Lay the tree down in the driveway with the netting still on, get the stand snug on the trunk so you can stand the tree upright. With the tree upright I use the speed handle and crank on the bolts as needed to get it straight. The whole process takes no more than a couple of minutes. I then haul it in the house with the stand on it and cut the netting after putting it in place. I find it's easier to tell if the tree is straight when the netting is still on.
    The tree always ends up straight and rock solid. I've been doing this for 5 years now and see no reason to look for a better set up.
    Best Tree Stand Ever-treestand-png
    Central CT
    I have a little 16" tall ceramic christmas tree from my Grandpa that he painted during arts&crafts at the old folks' home. It stands on its own just fine, and doesn't get needles all over.
    Last year I modded it by taking out the plug-in incandescent bulb and holder, and replacing it with an LED puck light. Grandpa would have been proud.
    It's obviously too short to put presents under, but I don't have a fireplace so Santa doesn't stop here anyways.
    Just for you.
    The Magic Fireplace
  1. Wanted - Parts & Tools | WTB: Pitbull triple tree stand (woodcraft stand OK as well)
    By xxaarraa in forum Wanted
    Last Post: 08-12-17, 04:06 PM
  2. New Front Triple Tree Stand Ready for Pre-Order!!
    By woodcraft_jason in forum Woodcraft
    Last Post: 07-06-17, 01:06 PM
  3. Would like to borrow Head/Tripple tree stand.
    By DoyleOil in forum Bike Maintenance
    Last Post: 08-13-12, 03:32 PM
  4. Tree Stand Attachment (for free or loan?)
    By mzdagrl in forum Wanted
    Last Post: 02-14-12, 07:25 AM
  5. WTB: Front stand triple tree type
    By xxdcmast in forum For Sale
    Last Post: 03-01-07, 02:19 PM
