Results 1 to 17 of 17
V6 vs. V8 in terms of oil
    Worcester, MA
    Honest question.
    Why does my wife's V6 Trailblazer take 7 quarts of oil and my V8 Silverado take 6 quarts of oil? Actually, the V8 trailblazer takes 6 quarts as well. So, I guess what I am asking is why would a larger engine take less oil than a smaller engine.
    LRRS EX #165 (formerly)
    Lifer FirstDuc-1098's Avatar
    Central Mass
    Re: V6 vs. V8 in terms of oil
    less space under the hood
    Senior Member cdseven95's Avatar
    I have one four cylinder that takes 4 quarts and my other takes 5.5 quarts.. I think it has little to do with engine size and more to do with amount of oil passages, passage sizes, oil coolers, oil filter size, etc...
    thats weird. 7 qts is unusual for a gasoline engine. Diesels take lots of oil usually. My 4.6l V8 takes 6, my 4.7l v8 in my dakota took 6, and the 4.0l v6 in my ranger took 6.
    it also could be due to the RPM's of the engine. Higher RPMs can mean the oil can get "spun up" and leave the crank dry.
    Old and Slow Sheppo's Avatar
    Westford, Ma
    Trailblazer and V6? I thought those were all inline 6's
    Posted by Jane in BoxChat
    Correct, standard they are inline 6's.
    They have to design the oil pan around the vehicle in many cases and create a "sump" that can hold volume. Usually smaller and more compact vehicles have less room in that area to work with and with an odd shaped oil pan, oil could be delayed to returning to the sump in time. So they make the pan bigger in some area's to store more volume
    When I had my GMC with the 8.1L gas, it took 7 quarts.
    Banned Rambunctous's Avatar
    Waterville Valley, NH
    Just got off the phone with Rosie O'Donell and she stated it is a conspiracy by Bush and Big Oil to destroy America.
    Worcester, MA
    Yes you're right it is an I6. Thanks for the explanation, that makes sense.
    The oil filter, while it's not difficult to access/change, it's in one of the worst spots for a filter. It hangs directly above a frame cross member; messy oil changes.
    Harlingen, Texas
    Quote Originally Posted by jcbell1007 View Post
    My 4.6 liter Cadillac Northstar takes 7.5 quarts, but my 6.0 liter Escalade takes 6 quarts. There's definitely room under the hood of an Escalade for a larger pan, so I'm not sure why smaller engines hold more oil!
    Just Registered
    Mar 2003
    Shrewsbury, MA
    some of the oil cooled Porsches take between 12-14 quarts...
    If you can't Race it or take it to bed, it's not worth having..
    Lifer ZX-12R's Avatar
    Candia, NH
    Because of their high compression, diesels have more blow-by than gasoline engines which causes the oil to deteriorate faster. Having extra oil volume allows you to run longer without having to change the oil
    Quote Originally Posted by Daytona440 View Post
    My father restored an older air cooled 911 and 912 and both took around 13 quarts if you completely drained the front mounted oil coolers and their lines that ran the length of the car.
    Lifer daviid's Avatar
    Oct 2004
    Plantsville, CT
    more area to disipitate the heat across. more place for the heat to go, results in less over all temp. less overall temp results in longer oil life
    -Benjamin Franklin
    #331 CBR929RE's Avatar
    Bridgewater, MA
    Quote Originally Posted by BMFR6 View Post
    try getting to the oil filter in a 2002 Chevy Cavalier 2.2L. Above the A arm behind the inner fender. and you can't get at it from the top because there's no open space anywhere under the hood. So you have to go in from the bottom but you have to bend your arm in an S shape and there's barely room to hold a filter wrench in an awkward position. I did that oil change for my sister once and told her never again.
    my 2.7L 4cylinder takes 6qts. always thought it was kinda weird but oh well I didn't design it.
    I93/495
    The Germans have been doing large sump capacities for years. Lots of hard running at high speed for long periods of time. Use a small sump capacity and you'll have sludge in no time.
    Lightly loaded truckscan get away with a smaller volume and help improve warm up time.
    My thoughts anyway
    2012 Tiger 800 XC
    Sep 2006
    Around the corner
    "Because moms in suvs spend more time beating the crap out of you stinggy men for money to pay for oil changes so engineers figured why not make it worth thier effort" by Rosie O'Donnell
    I-6 vs. V-6 vs. V-8 vs. german I-4's vs. cadi's vs. diesel vs. hydro vs. electric vs. hybrid vs. aluminum vs. cast iron vs. delorean vs. S7 vs. all the reasons ^^^^ and your average comes to the same answer
    "I think my Momz gone C-R-A-Z-E-E"
    The rule is:
    Lifer zxme's Avatar
    Mar 2007
    Mass
    My wife sold her cavalier that she had for 10 yrs, and i did every oil change on it. After a few times it was a cake walk. well maybe a dozen times
    Sep 2007
    nkRI, nashuaNH
    my 99 blazer only takes 1 quart..... Every 2 weeks!!!!!
    baaaaaa hahahahahaha!
  1. Replies: 1
    Last Post: 01-16-13, 04:17 PM
  2. Terms for Female Masturbation
    By Sheppo in forum Off-Topic
    Last Post: 12-13-12, 11:02 PM
  3. Stock Market Terms Year 2008 & Beyond
    By KillBill in forum Off-Topic
    Last Post: 10-08-08, 07:29 PM
  4. new terms I've learned since I join the gang
    Last Post: 11-14-02, 11:28 PM
