Save on a Brand New Kit. I got this on mistake & I ended up stuck with it. So buy for lees than what I paid for it. Pick it up and take it away.. Shipping is available for the cost from 01702.
This kit brings the front end up level to the rear seeing these models come with the rear end 2-2.5" higher.
PN# FL220
THIS FITS: 1997-2002 FORD PICK UP FULL SIZE
"Trail Master provides leveling kits to improve the looks of most trucks. Each kit provides the required front lift height to make the truck sit level. Kits include urethane or aluminum spacers to gain the required height. All kits are complete, including the required mounting hardware and instructions."
$50, I paid 65+ shipping costs...
www.tailofthedragon.com
You got my Number come get it any time before I leave for Pittsburgh again... Which might be as early as Friday Morning?
Those will only work on 2wd '97-'03 F-150's. 4wd's had torsion bars, just in case you didnt know.
Ahh yes 2 WD, but still 97-02. Not sure it will work on 03? Only recommended for 97-02.Originally posted by mustang183
Yes you can, but you may need an alignment after or your tires will wear un-even.Originally posted by bigred875
damnit! can you adjust the torsion bars to level the frt end of the 4x4?
All you have to do is tighten up on the two torsion bar adjusting bolts.
