Never really wanted an SV for the track, but I needed something and this fell into my lap at the right time. Now something else may be falling into my lap but I have to unload this first.
99 SV650:
Completely drilled for safety wire
Bodywork is almost 100%. I sanded everything down and repainted it in the off season, repairing some cracks with fiberglass some scuffs from transporting in the trailer and what not but all cracks have been repaired. The only issue is that I have been dragging the rear right corner of the bellypan which i will fix before i hand it off if the buyer wants. Bodywork mounts VERY solid.
Penske triple clicker rear with remote reservoir
RaceTech fork internals
GPR steering damper
Woodcraft clip-ons
Woodcraft rear sets (GP shift)
Vortex threaded gas cap
Bad ass frame sliders (HUGE! bolt right to the frame)
New o-ring 520 chain conversion with new sprockets
Aluminum coolant overflow tank mounted on subframe
Lightened and braced subframe.
Braided brake lines
GSXR Radial Master Cylinder
Factory wire harness cleaned up and all non essential wiring tucked away
New Fairing stay
New Air filter
i've changed the oil after all 3 weekends this year
I put pirelli trackday slicks on it before the season started. front has 6 days on it, rear had 2.5 and i caught a piece of safety wire that punctured, will include the punctured one if YOU want to plug it, currently has a take off pirelli track day slick on the rear
I also did a ton of minor maintenance/ clean up stuff before the season started. New Throttle side switches (old ones were all cracked apart) new throttle tube since old one had the peg cut off and it was rotating, has a 1/4 turn cam. re-ran all the crank case vent tubes and go the correct collector box and mounted it to the airbox. installed a tach with shift light, new spark plugs, flushed front brakes, mounted the front rotors to the rain wheels.
Bike comes with spare wheels, front and rear, good rains mounted on them only missing the rear rotor.
$3,000 obo
Hmmm
So hard not to buy a fucking SV. I should stay away from the Internet.
99 is carbs. If this was fuel
Injected it would be in my garage now
Yea, 'cause the hawk is FI and all
Just teasing ya Sav.
Everybody thinks fi is more reliable, however when fi has a problem it's almost always more expensive to fix and often harder to diagnose.
Coming from a guy who built his own FI system from the bare PCB, carbs are way simpler. You get em set up right then don't worry too much about it on this bike SAV. Might leave 1/2-2hp on the table depending on the baro pressure, but at *our* level it doesn't matter, suspension will get you seconds, motor will get you scratches. Buy it
Sale pending...
Sold
LRRS Am #331
LRRS Am #331
Get your priorities straight!
