This is what I have left of my 1098. All parts are in great shape unless noted. Prices are negotiable, and I'll get some pics up soon.
-Swingarm complete with axle $125
-Custom burned ECU by Boulder Motorsports. This is an improvement over the DP ecu that is supplied with the 70mm exhaust $250
-Ignition surround with immobilizer ring (whatever its called) $20
-undertank, underseat panels, stock, $40
-Air intake ducts $35
-Subframe $100
-exhaust mount for underside of subframe $20
-Main Wiring harness with battery box, regulator, coils, etc. $100
-Stock sprocket carrier (2) $15 each
-Rear rotor $45
-Wheel side axle nuts (2) $15 each
-Sprocket side axle nuts (2) $15 each
-Custom shortened 1098 ride height adjuster $100
-Racetech R3G rear shock custom built to fit the linear rear suspension link From Bobby Fongs AMA bike) $400
-Oil cooler with lines $40
-Stock clutch cover, painted black with some paint missing $20
-Left side switches, switch pod. hole drilled for traction control switch mount $50
-Kill/start switch $40
-Front sprocket nut with lock washer $15
-Seat $60
-Swingarm pivot bolt $15
-Engine mount bolts $10
-Clutch actuator rod $20
-Gauges and ignition (1 key) $300
reply here or shoot me a PM
Slipper clutch sold, everything else available.
open to offers, I really dont want to ebay these parts
Anyone....
I also have a brake and clutch lever with actuator pins. The clutch lever has the ball broke off the end.
lowered prices...
bump...
bump...
wow, 1500 views, someone must want something. Shoot me an offer, worst I'll say is no..
