For sale are two FLOTEC pedestal style sump pumps. Both are 1/3 HP model FPPM3600D and work without issue. They both have plastic hose attached that extends over 20 feet.
The first was the primary pump. It has a small amount of rust as seen in the pictures and is the one with the silver top. The rust does not at all interfere with its operation. There is a wood block attached so that it may be bolted or screwed to a support to keep it from tipping. $30 for this one.
The second was the backup pump. It is hardly used and is fully operational also. Cosmetically it is like new with the exception of some paint splashes as pictured. $50 for this one.
Alternatively you may purchase both together for $75.
Cash only, and I'm located near Haverhill, MA. PM if interested. Thanks
