2
She's an absolute unit. Single-stage, oil-less compressor rated to run continuously, 5 cfm @ 100 psi. Typically oil-less are considered loud, this is not loud, 82 decibels. These are built to be run in a lab environment where oil cannot contaminate the air lines. It's been sitting in my barn for several years, pulled it out yesterday and got it cleaned up and tested. Everything works as it should. Dual voltage motor can be run at 220/120V @ 10/20 Amps. Plumbed with a 3/8" outlet; have it reduced to a 1/4" quick connect for testing. I have it mounted on some 4x4 on swivel casters for easy mobility as it's fairly heavy. I have it on Marketplace for $2,500, will do better for the NESR fam, make a reasonable offer. Located in Rehoboth, MA. Can deliver or meetup somewhere.
Comparable unit (not dual voltage) at Grainger
https://youtube.com/shorts/9N1Pyr7ZT4U?feature=share
Last edited by loudbeard; 06-05-23 at 01:34 PM. Reason: Added pics, updated description
Just to add a note on the price as there have already been a lot of clicks; I will do a nice deal for any NESR member in good standing. Please take any discussion of that to PM if you're interested. Full disclosure, I only have about $50 into this thing. It was given to me by my former employer, who purchased it for a backup compressor, but it was too small for that shop....we ran a 10 HP rotary screw.
That's a beast for sure and means bidness. I wish I had a need for it...
Side note (and TOTALLY not meant to mess up your thread): A friend recently refurbed an old gas operated absolute beast of an air compressor. Thing is astounding...
No worries! The gas ones move a TON of air, have seen some IR units on trailers at plant shutdowns I've worked where they hook up what I can only describe as a fire hose of an air line!
This one doesn't move that much air, but the air it does move is very high quality. Just add water separator and go!![]()
