1
For sale:
Hawk GT Race Bike - 663 cc Motor Specifications (By Hord Power Dec, 2013):
•JE 663cc Hi-Comp 80.0mm Bore Kit
•HPR Stage 2 Heads w/+2mm Intake Valves (28.0mm) Note: NGK D9EA Spark Plugs Only
•HPR/Megacycle #9 Cam w/Slotted Cam Shaft Sprockets
•Falicon Supercrank Modification (Magna Fluxed, Lightened, Polished and Balanced)
•Carrillo “H” Beam Connecting Rods
•Keihin 39 FCR carburetor set (Open Velocity Stacks w/Storage Balls
•EBC Race Clutch Fibers, Steels & HD Springs
•HPR Factory Pro Shift Kit
•Stainless Steel Case Bolts w/Gold Anodized Clutch, Alternator and Valve Covers
•Total Loss Ignition. Flywheel/Alternator Removed w/Custom Crankshaft End. Race wire harness
•Mikuni Vacuum Fuel Pump w/Custom Subframe Mounting & Fuel Line Quick Disconnect
•Custom Built M4 Race Exhaust Headers w/TYGA Maggot Exhaust Can
•Runs Optimum on 100 Octane Race Fuel. 150-160* Race Temps
•Final Build produced 78hp at 49lbs Torque on HRP Dyno Test (12/07/13)
(Note: 23.0 Hours on motor. See Log Books)
Hawk GT Race Bike - Chassis Specifications:•315# Dry Weight
•1989 GSXR 750 43mm Front Fork w/3.5 x 17 wheel, Race Tech Valves and 100kg Springs
•1994 VFR 750 5.5" rear wheel and matching axle/spindle
•Front Brakes: Four Piston Nissin GSXR Calipers, EBC 320mm Wave Rotors, GSXR 600 Nissin Master Cylinder and Titanium Rotor & Caliper Bolts
•Rear Brake: Upside Down Brembo Dual Piston Brake Caliper with Quality Machine lightened stock rotor
•GSXR 750 Front Fender and Radiator w/Silicon Rubber Radiator Race Hoses
•Woodcraft 43mm Clip-ons w/Hand Guards & Bar End Sliders
•Woodcraft Rearsets w/Standard & GP Shifting Assemblies
•Daytona H20 gauge
•Silicon Hose Crankcase Breather System w/Dual PVC Overflow Bottles
•Vortex V3 Race Fuel Cap (Black Anodized)
•Scitsu 10,000 RPM Race Tachometer w/Custom Built Fairing Stay and Light Panel and an Open Circuit Tethered Kill Switch
•Ballistic N-Cad Battery w/Hi-Perform Frame Case & 12V Quick Connect Charging Leads
•Penske 8987 Shock (HPR/Factory Valve and Sprung for 250# rider on 11/2014)
•520 gearing set (15/16/43/44/45T)
•DYNA Mini Coils w/NGK Plug Wires
•Shindy 120mm Universal Steering Stabilizer w/43mm Fork Clamp
•Hi-Perform Rear Subframe, Titanium Hardware & Airtech RS125 (“04-07”) Seat/Tail Section. Adjustable PVC Marine Plywood Seat Height Shims (1/4” – 3 Each)
•Full Front Fairing Upper (Sharkskinz SV650) w/Quick Release Side Pins and Airtech Vintage Type Belly Pan Lower. Patriot Blue paint w/Eastwood 2K Ceramic Epoxy Gloss Clear Coat (Fuel resistant) and clear Stomp Grid Tank Pads
Professionally build and maintained. Race Log Book available upon request. Current Leak Down Test @ 2% Front/Rear (Cold). $7,500.00 w/Spares, Race Rains(Zero time on rains), GSXR front wheel/VFR spoke rear wheel, JE 663 ring/top end gasket set, FCR carb throttle cable set, EBC brake pads, spark plugs/oil filters and 520 gearing set w/spare chain. Many additional race spare parts available but not included in price (Motor, carbs, forks, frame, cases, clutch, CDI, wheel sets, fresh Dunlop slicks, QStarz 6000, Chicken Hawk tire warmers, AMB transponder, Pit Bull stands (F/R) etc. Too many to list). PM me or call Michael at 802-598-0980 if interested. You will not be disappointed with the quality and/or performance.
If anyone knows Mike or has seen his stuff, you know it is absolutely pristine and done right! And a nice guy to boot.
Sorry to see you sell Mike, how are you healing up? Plans to keep racing, or a hiatus?
Whoever buys will be getting a real cherry.... good luck with the sale
Zip-Tie Alley Racing
LRRS/CCS #103
Gosh that's pretty.
You really gotta love Hawks to buy this bike. Like REALLY love Hawks.
Everytime I see one for sale or being raced, I kick myself for selling mine....
SOLD![]()
