FREEEEEEE!!!!!
Whirlpool GOLD Ultimate Care II Heavy Duty-Super Capacity Plus Washer and Dryer, Unknown Manufactured date? These are at least 5 years old.
They both work well but so you have the complete details they do have minor problems. They wash and dry abbsolutely fine!
Washer model # GSQ9364HQO
DRYER Model # GEQ8858HQO (Electric)
Washer issue: During the first spin cycle there is a clunking sound when it strarts this cycle, then stops and everything runs fine. Can be used as is without repair, just have to feel comfortable with the "Clunk"
Dryer issue: Heat cycle control. Dryer starts and runs fine, but the timer for selecting the dry cycle will not engage and the dryer does not shut off on it's own. It does run and does dry everything very well. Can use without a repair. Could be a minor/quick fix with out new part or by simply replacing the control. (Very easy to replace, couple of screws and a few wires to disconnect and reconnect)
Both units comes with everthing you need. Hot & Cold Hoses, power cords. Your plug connector/Outlet may be different from your outlet. A Replacement cord is cheap and easy to swap with the correct one from Lowes/Home Depot etc.
These are only $0 to move them quick, very cheap even with the problems, I am not a mechanic so I can not fix these. They are $0 as is.
Delivery would cost you $100, but I don't want to deliver, just come pick them up and get them out of my garage.
www.tailofthedragon.com
For 100$ thats a a great rag/dirt riding gear washing machine/dryer set. Well worth it for those who don't want to hear their wifes crowing about that sorta thing…![]()
FREEEEEEEEEEEEEEEEEEEEEEEEEEEEEE
Anybody wants to come pick these up they are yours free.
GET THEM OUT OF MY GARAGE!!!!!
Seriously nobody wants FREE working washer and dryer? Wow.
I have been using these in this condition for 6 months without any issues, prior to the 6 months the dryer issue was not there. Washer has always made that noise, but works mint...
Keep a cooking timer near you set for 1 hour and that will be you r cheap fix for the dryer!
Seriously FREE!!!!![]()
