Page 1 of 4 1234 LastLast
Results 1 to 25 of 84
80s Suzuki DS80 rebuild has begun!
    TWINS! xrocket21's Avatar
    Central Maine
    The start!
    80s Suzuki DS80 rebuild has begun!-20200527_160809-jpg
    Central Maine
    Re: 80s Suzuki DS80 rebuild has begun!
    1 hour later
    80s Suzuki DS80 rebuild has begun!-20200527_175902-jpg
    Have any interest in a 1982 KDX80? I'm going up to the lake house in Greene, ME later this month for an easy pickup.
    I remember those! Oh, and an 82 KDX 80 was a killer bike!
    Central Maine
    Maybe.... I guess PM me the details?
    Central Maine
    Of course had to drill out a bolt. These Phillips heads will be replaced with stainless hex head.
    80s Suzuki DS80 rebuild has begun!-20200527_182827-jpg
    This old girl hadn't been cleaned for years then sat for a decade.
    80s Suzuki DS80 rebuild has begun!-20200527_184253-jpg
    I just need to find a throttle tube. this one is partially broken and I worry about the throttle sticking.
    Central Maine
    How it sits now
    80s Suzuki DS80 rebuild has begun!-20200527_193032-jpg
    I plan to clean up the frame and hit it with blue rustoleum
    80s Suzuki DS80 rebuild has begun!-20200527_194053-jpg
    Get yourself an impact driver, and a set of JIS screwdrivers, you'd be amazed how many of those stubborn 'phillips' head screws you thought you'd have to drill out come out without any drama after.
    Central Maine
    I don't have official JIS this big, but I tried drivers of various home grinds. I also hit it with the impact driver with no luck. Of course it was the one partially obscured by the foot peg so I couldn't get a good purchase on it. I should have hit it with the blue tip wrench, but I thought the cover was plastic. Got the head mostly cut off with my dremel, but the battery died of course. It drilled out in pretty short order.
    Central Maine
    The new parts pile
    80s Suzuki DS80 rebuild has begun!-20200530_150516-jpg
    Where's the ported big bore cylinder and piston?
    Central Maine
    Got her down to frame! Cleaned everything with a pressure washer a tub of soapy water. Oil tank had 1/4" of sludge on it. Decided without sandblasting the frame, id never get it good enough to paint so im leaving it.
    80s Suzuki DS80 rebuild has begun!-20200607_110500-jpg
    Painted a few bits I could wire wheel good.
    80s Suzuki DS80 rebuild has begun!-20200607_183453-jpg
    Lifer LuvDog's Avatar
    Ashland, MA
    You could try some Paint stripper. I’ve used the citrus based stuff before and it worked well
    2003 ZX7R
    1995 916
    Lifer JohnnyV's Avatar
    Westborough, MA
    This was my DS80 hotrod project from years ago. Fun little bikes
    Central Maine
    80s Suzuki DS80 rebuild has begun!-20200609_124402-jpg
    Cleaning up and repacking the steering head bearings. The lower balls went EVERYWHERE on disassembly!
    Central Maine
    What should I use for replacing the oil in the bottom end of the motor/tranny?
    Central Maine
    Youre making me wish I painted the frame
    Looks badass though
    I think as long as it's clean oil, the sky's the limit? IIRC the factory called for 10w40.
    Central Maine
    Just plain 'ol motor oil?
    Motor oil, ATF, 80/85w gear oil, it's a splash lube gearbox and clutch, no plain bearings or pumps/etc so it'll be VERY tolerant of just about anything. About the only item to put any thought into is the clutch, an oil with excess say, Teflon I'd avoid.
    Central Maine
    Thanks man! I think tires should be in this week, I need to clean the carb in the motor and do that fluid/plug change, a little more re-assembly, and I should be kicking it over by the weekend!
    I was given a couple gallons of marine 2-stroke oil, I assume I can use that in the oil tank on this? I mean, its a 1985 smoker, how picky can it be?
    Make sure it's injector oil, and not intended for premix use only. You don't want to gum up the pump and starve the top end of oil after all this effort.
    Central Maine
    80s Suzuki DS80 rebuild has begun!-20200609_160428-jpg
    80s Suzuki DS80 rebuild has begun!-20200609_161036-jpg
    New sprocket vs old sprocket!
    Central Maine
    80s Suzuki DS80 rebuild has begun!-20200609_171026-jpg
    I didn't even realize it was Amzoil till I took the pic lol. Got 2 gallons free. It is injector so it should work. The gn4 I use on the rc51 so I have spare. Might use the castrol too as it was free and I have no other use for it.
    Central Maine
    The cloth seat strap was tucked underneath, and other than being wrinkly from being tucked, looks pretty new from being hidden. Should I re-attach it so it goes over the seat, or keep it tucked? I feel like its a good handle for picking up the rear and might keep little buns from sliding off the back when the powerband kicks in, but it also looks pretty clean without it.
    Thought?
  1. 1990 Suzuki DR350 Rebuild
    By Tekime in forum Bike Maintenance
    Last Post: 10-22-19, 01:40 PM
  2. Project Suzuki DS80
    Last Post: 08-20-19, 01:28 PM
  3. 87 Suzuki DS80 dirt bike - $200
    By breakdirt916 in forum For Sale
    Last Post: 07-01-11, 02:15 PM
  4. Replies: 14
    Last Post: 03-20-05, 11:43 PM
