I am the proud owner of a hunk of crap '86 Yamaha XT600. It was free, so I figured I could tinker with it in my spare time. It has no become an obsession to get this running. I have never had it running, and it was not running before it was in my possession, so there is a lot of work to be done. I decided to start with the carb. I ripped it out, tore it apart, cleaned all the bits and looked through the fiche on bike bandit to see if anything was missing, sure enough, lots of things. As I searched deeper, I realized that the carb is from an '82 XT550. Same concept, being a YDIS system, with a small primary, and a vacuum secondary with a shared float bowl.
On the '86 carbs, there is a fitting at the bottom of the float bowl that runs to the jet of the secondary to feed that fuel. On the '82 however, there is not, and I can not figure out for the life of me how it gets fed. My question is, can I add a fitting to the bottom of the primary bowl, and use it to feed the secondary?
Steve
Work Hard---Play Harder
Thanks Mondo! I'm thinking that its free, and whats the worse that can happen, I have to get a new carb anyways. Probably just going to go for it.
Steve
I too can watch. HAHA Let me know if you need a hand.
LRRS 878 Clapped out Gixxah
will do. Happy B-day BTW Jack!
Steve
This thing has me
Steve
Thanks Steve. That's a sweet looking scooter.
That chain looks *tight*. The older dual carb setups were a PITA, whether it was on an XR/XL or the TT/XT.
That definately has the potential to be restored into a very nice play bike!
The chain is beyond tight. Everything about this bike needs a fix. Notice the wooden block under the rear fender...supporting the frame since the spring/shock combo in there cant do it... Thing is a mess.
Steve
Still trying to sort the carb issues out. Basically sourcing parts
Steve
Yes, the ramped preload collar on the shock tells me that shock most likely does not belong on that bike.
Thank God for E-Bay.
I had a TT350 with an Ohlins shock. It was a great little bike! My brother had an XT600 that served him well in Germany.
Take your time, source the correct parts, and you will have a very nice bike when you are done.
