Results 1 to 15 of 15
Budget (free) bike build
    Senior Member klepsta's Avatar
    Feb 2008
    Stoneham
    I am the proud owner of a hunk of crap '86 Yamaha XT600. It was free, so I figured I could tinker with it in my spare time. It has no become an obsession to get this running. I have never had it running, and it was not running before it was in my possession, so there is a lot of work to be done. I decided to start with the carb. I ripped it out, tore it apart, cleaned all the bits and looked through the fiche on bike bandit to see if anything was missing, sure enough, lots of things. As I searched deeper, I realized that the carb is from an '82 XT550. Same concept, being a YDIS system, with a small primary, and a vacuum secondary with a shared float bowl.
    On the '86 carbs, there is a fitting at the bottom of the float bowl that runs to the jet of the secondary to feed that fuel. On the '82 however, there is not, and I can not figure out for the life of me how it gets fed. My question is, can I add a fitting to the bottom of the primary bowl, and use it to feed the secondary?
    Steve
    Work Hard---Play Harder
    Jul 2008
    Marlborough Mass
    Re: Budget (free) bike build
    best of luck with this thing brother!
    I'll stop by and lend a hand or drink beers and watch you work on it if you ever need a hand
    Feb 2008
    Stoneham
    Thanks Mondo! I'm thinking that its free, and whats the worse that can happen, I have to get a new carb anyways. Probably just going to go for it.
    Steve
    Jul 2008
    Marlborough Mass
    free def is good
    Lifer wiggeywackyo's Avatar
    Feb 2009
    City
    I too can watch. HAHA Let me know if you need a hand.
    LRRS 878 Clapped out Gixxah
    Feb 2008
    Stoneham
    will do. Happy B-day BTW Jack!
    Steve
    Feb 2008
    Stoneham
    This thing has me
    Steve
    Feb 2009
    City
    Thanks Steve. That's a sweet looking scooter.
    Central MA
    That chain looks *tight*. The older dual carb setups were a PITA, whether it was on an XR/XL or the TT/XT.
    That definately has the potential to be restored into a very nice play bike!
    Feb 2008
    Stoneham
    The chain is beyond tight. Everything about this bike needs a fix. Notice the wooden block under the rear fender...supporting the frame since the spring/shock combo in there cant do it... Thing is a mess.
    Steve
    Jul 2008
    Marlborough Mass
    so what you doing to this bad larry now
    Feb 2008
    Stoneham
    Still trying to sort the carb issues out. Basically sourcing parts
    Steve
    Jul 2008
    Marlborough Mass
    i hate playing that game
    Central MA
    Quote Originally Posted by klepsta View Post
    Yes, the ramped preload collar on the shock tells me that shock most likely does not belong on that bike.
    Thank God for E-Bay.
    I had a TT350 with an Ohlins shock. It was a great little bike! My brother had an XT600 that served him well in Germany.
    Take your time, source the correct parts, and you will have a very nice bike when you are done.
  1. Wanted - Motorcycles | Posting for a friend - bike on a budget
    By -Dutch- in forum Wanted
    Last Post: 04-27-16, 11:21 AM
  2. Sporty standard first bike on $3000 budget
    By SRTie4k in forum Wanted
    Last Post: 05-21-13, 07:38 AM
  3. Building My Budget Bike Garage
    By yesterdayze in forum General Bike Related
    Last Post: 12-10-09, 11:57 AM
