Results 1 to 14 of 14
replaced silencer = no start?
    So I replaced an FMF shorty with the stock silencer on a '98 RM125, 144 kit, stroker kit, with maybe 20(?) hours on the top end.
    The bike started first kick as usual, but after about 30 seconds of running/revving as usual, it stalled.
    I checked the tank and the gas looked low, but not empty, so I made more 32:1 and tried again. No dice.
    I tried the roll start, but it didn't work.
    I kick started it over again, and it started (and revved), but then stalled within 15 seconds.
    I tried the roll start again, and had it roll about 20 feet in 4th gear, but it didn't sound like there was a fire in there at all.
    Could the stock silencer affected the way that it runs (back pressure?), so much so that it won't start?
    It was smoking slightly the last 2-3 times I rode it, so I was thinking it could be the plug, but I called 3 motorcycle dealerships, 2 auto shops, and nobody stocks the plug. Apparently it's also a $36 spark plug
    any ideas?
    Old and Slow Sheppo's Avatar
    Westford, Ma
    Re: replaced silencer = no start?
    I can't imagine that's the issue. I've never had a silencer do that. When was it last run? is the carb needing a clean? Spark even when it wont start?
    Posted by Jane in BoxChat
    live to ride seth399's Avatar
    Feb 2007
    CA
    there is a rat stuck in the silencer...remove and enjoy riding
    aha but seriously, there is no way that should be related unless it is actually plugged, but it wouldnt have started in the first place.
    LRRS #399
    MX #505
    Sep 2007
    Middlebury VT
    Remove plug and inspect.
    Very soft wire brush to clean if it is gunky or burn carbon off.
    Confirm fuel delivery to the carb.
    Air filter free and clean?
    Dec 2005
    Near The Dragon
    2 strokes are very sensitve to back pressure, but as said, i doubt that is the cause.
    sounds like fuel starvation regardless of any indicators to the contrary.
    fuel line pinched?
    getting flow out of bowl drain?
    petcock on?
    Get out while you can
    Find your own path
    Lifer lrrs313's Avatar
    Asheville, NC
    After checking all of the above, if it still won't start:
    Pull spark plug, pour a little oil (tablespoon or so) into the cylinder, replace spark plug, attempt to start.
    If it starts and runs briefly, replace piston and rings. 2 strokes are very sensitive to compression and refuse to start when it's too low. And usually it happens very suddenly. The bike will run great, you shut it off, and it won't start again.
    it was the plug
    I pulled it (came out black), tied some speaker wire between the plug and the cylinder head, kicked it over, and saw NO spark.
    Got a new plug from peformance cycles a few minutes before they closed and swapped it out: started first kick
    I even took this opportunity to turn the air screw in 1/4 turn increments until it smoked the least and was smoothest with mid throttle: 2-1/2 turns was the magic #
    As it turns out, the OEM plug is a $36 plug that will last awhile, but is only available as a special order item. OTOH, there is a cheaper version available for $6 that the previous owner was using, but it won't last as long (5? tanks worth). I went ahead and bought 3 of them and will keep 2 on when hitting the trails
    OK, but turning the airscrew IN richens the setting even more. Turning it OUT leans it up.
    2-1/2 turns out indicates that your pilot jet is too rich and you should go to the next smaller number. 48 to 45 for example. You want to be somewhere between .5 and 2 turns out.
    btw, I somehow missed that your bike is a 144 stroker. I've always wanted to try one of those!
    oops, I can't count. I just checked and it's 1-1/2 turns out from being screwed all the way in.
    you riding this weekend? this is my first 125 2-stroke and I'd like some feedback from the pro's on what I bought
    Saturday, Crow Hill!
    Member Fast_Eddie's Avatar
    Jul 2005
    Framingham
    Bhavesh, You should be able to run a B7ES plug in your bike for the woods.
    hmm...unlikely for me, but we'll see
    how about Franklin sunday?
    Quote Originally Posted by Fast_Eddie View Post
    sweet, cheap alternatives rock
    also, even with 1-1/2 turns out, after a quick warm up run and a couple full-throttle rips, the spark plug still comes out black.
    It's not oily/wet, but it's still black. Should I be turning the air screw out a little more?
    Jul 2005
    Framingham
    Go another 1/4 turn out on the air mixture screw and lower the needle 1 clip position. you probably will end up re-jetting at some point, but this should be enough to keep you going without fouling flugs.
    And no to franklin on sunday. I'm hittin the Hill tomorrow. Day on the lake Sunday.
  1. Floating Bridge to be replaced
    Last Post: 07-10-14, 07:06 AM
  2. My VFR is gone, replaced by a ...
    By SteveM in forum General Bike Related
    Last Post: 08-17-10, 07:47 PM
  3. What tire replaced the Corsa III?
    By JettaJayGLS in forum General Bike Related
    Last Post: 06-11-10, 12:44 PM
  4. Silencer options?
    By Fitz in forum Pit Area
    Last Post: 03-10-10, 12:47 PM
