Results 1 to 5 of 5
Headset Bearing
    Senior Member DBB's Avatar
    Feb 2009
    Massachusetts
    Headset Bearing
    If I put the lower part of the triple clamp in the freezer for an hour or two a warm bearing should just slide on,....no?
    Lifer slammp's Avatar
    Jul 2008
    Massachusetts
    Re: Headset Bearing
    When I replaced mine, I just bought a piece of pvc that was the same diameter from Home Depot and hammered it on. Especially where it's the bottom bearing, the weight of the fram will also force it down when you tighten everything up.
    Re: Headset Bearing
    i did the same thing. Read page 1 on the thread.
    yes, freeze the new ones. after the new ones are dropped in, then use heat for the bearings to expand
    Wirelessly posted (BlackBerry8530/5.0.0.337 Profile/MIDP-2.1 Configuration/CLDC-1.1 VendorID/105)
    Freeze the neck, heat the bearing races, press on.
    Feb 2009
    Massachusetts
    Re: Headset Bearing
    ok kewl thank you. I'm working on a dirty bike but it doesnt look like it makes a difference.
  1. For Sale - Other | Cardo ScalaRider G4 bluetooth headset
    By nhbubba in forum For Sale
    Last Post: 02-10-14, 07:20 PM
  2. Made a custom headset bearing nut tool
    By SprintPoser in forum Bike Maintenance
    Last Post: 07-15-13, 08:46 AM
  3. Jawbone Era headset (Barely used) $50
    By ae in forum For Sale
    Last Post: 06-08-12, 11:00 AM
  4. Chatterbox Xbi Bluetooth Headset
    Last Post: 02-06-11, 04:45 PM
