Results 1 to 6 of 6
Gear ratio question
    FYYFF theothersean's Avatar
    middle of nowhere
    Gear ratio question
    So I don't know too much of the cause and effect of gearing ratios which is why I ask this question.
    I ordered a chain and sprocket for the drz not realizing until I have the old stuff off, the new stuff out of the package that I ordered the stock gearing for the drz E not the S model which is the one I have.
    the difference is
    the s model has a 15 tooth front sprocket and a 44 tooth rear
    the E has a 14 front 47 rear.
    so I have dropped 1 on the front and added 3 to the rear.
    so have I basically just created a wheelie machine with more revs in the low range and with less of a top end.
    is first gear now shorter and second gear more useable?
    thanks
    12 Vstrom 1000
    09 KLR 650
    (hers)
    13 Vstrom 650ADV
    09 KLR650
    Gear ratio question
    you've made each gear a little shorter. If 2nd a little too tall then yes, it's more usable.
    Gear ratio question
    Should be much betterer in the woods. It will top out at 65 mph or less though.... That's a MASSIVE gearing change.
    Littering and........
    Jul 2004
    Vermont
    Gear ratio question
    I'm surprised it fit...the E model has about 10 more links in the chain to accomodate the larger sprocket.
    It should nonetheless be a much better woods bike, but you will notice a huge difference in your top speed.
    Gear ratio question
    Ya. It's the same as goin SIX teeth bigger in the back. you will lose 25-30mph in top gear.
    middle of nowhere
    Gear ratio question
    Quote Originally Posted by highsider View Post
    I bought the kit, front, rear sprocket and chain. I just happened to order the e kit by mistake.
    Oh well, who knows I might like it better for trails now.
    12 Vstrom 1000
    09 KLR 650
    (hers)
    13 Vstrom 650ADV
    09 KLR650
  1. Question about track day gear
    By whynot in forum General Track Day Talk
    Last Post: 11-06-18, 03:15 PM
  2. Gear Repair Question
    By DroFiveOh in forum General Bike Related
    Last Post: 06-08-15, 10:15 AM
  3. Gear ratio questions?
    By R7 in forum Pit Area
    Last Post: 05-10-04, 10:27 AM
  4. Gear ratio chart
    By need4speed in forum Pit Area
    Last Post: 05-25-03, 05:45 PM
