Page 26 of 28 FirstFirst ... 616171819202122232425262728 LastLast
Results 626 to 650 of 696
I'm dumb. Y'all know it. So make me be less dumb. KDX? CRF? KTM?
  1. #626
    Re: I'm dumb. Y'all know it. So make me be less dumb. KDX? CRF? KTM?
    Why not spend $10 and put a cheapie bike speedo/odo on instead of that spendy thing?
    I have a vapor I'd sell you for $60. I believe the kit is for a DRZ.. but you can probably get creative.
    wth?!
    doesn't tusk make a kit that fits + front brake light switch?
    should run everything off its self contained battery kit minus a headlight
  4. #629
    Tusk does have that, which may be a cheaper route. Would still need a headlight, headlight switch for hi/low, and reg/rec from the KTM.
    Did more digging today, I have the "2k3" stator which is apparently the one that can handle a headlight.
    No chance of it ever passing inspection in MA though. Would still need DOT gnawbees and a chain guard. Plus no title, so it would have to go VT and stay VT.
    If you aren’t going to expect it to pass inspection, just get a trailtech headlight or whatever, and then a sicass brake/tail kit, and it’ll be on when the bike is running, and that’s it.
  6. #631
    Nov 2009
    Bristol County
    Decoding my VIN, this is a 2008. Ugh.
    So the good news is that I think if you wait till the clock turns 2018, you're exempt from needing an Odometer statement - which would require signatures from previous owner.
    nedirtriders.com
  7. #632
    I have a factory headlight for my '05 300 EXC, as well as a Trailtech dual headlight. If you need 'em just for registration, you could borrow one; or I'd sell you one if you wanted to keep it.
  8. #633
    Specifically in VT?
    Sweet. I can handle that wait.
    So all in to get the thing with directionals, brake lights, mirror, horn and headlight, probably be about $300. That's not too bad in the grand scheme of things.
    I may take you up on that. I don't think the wiring is different, but I'll have to check.
    More research:
    200XC has no "wiring harness" (part 54811075100).
    The 200XCW has the "wiring harness" and voltage regulator.
    Same stator, CDI, etc.
    Voltage regulator is about $58 for the KTM OEM (Generic exact replacement, Amazon, $27.95), wiring harness is $28.
    If I do both of those, I'll be able to run any lighting kit designed for the XCW.
    Getting closer.....
    I guess you really should have held out for an XC-W. I didn't realize there were this many deltas between.
    The KTM instrument gauge kit is pretty choice. I know how to use about 10% of it. But you can do all that x-miles to mark jazz and stuff. Although you apparently cannot reset the hour meter after a rebuild.
    I'll go one of the TrailTech gauges. It's got all the stuff I could hope for. Besides, without the KTM wiring/speedo pickup/etc, I can't run the stock KTM one.
    There are some significant differences in the XC to XCW when it comes to wiring/electrical. Hoping for my needs, the harness and regulator will get me to where I need to be.
    Just the parts I'd need to buy (+ cost of yours) to make it work for the KTM would be more than buying a brandy new one, so I guess I'll pass. Nice that TrailTech tells you exactly what parts come in each bike's kit.
    your dads in NH, why not just register it to him? you wont need the speedo, blinkers or half the other shit you posted. just headlight, tail light, brakelight. i cheat a little on the chain guard and horn as i just inspect my own bike.
  14. #639
    atta boy...price is coming down
    but why not what Chipper suggested? head/tail/brake light + VT registration...do it XR250 style and run the whole thing AC with a regulator
    yeah if the price comes down enough, sure...but remember what 99% of peeps say about smoking on the street. It's a novelty, but it kinda sucks.
  15. #640
    My plate is there to connect trails and not get hassled. My 200 has to be the worst dual sport I've ever ridden. The 5xx lbs 'strom is better there.
    Also, I haven’t advocated for a by reg, I don’t know why people are putting words in my mouth. It’s a ktm, a mass title should be easy.
  17. #642
    I have no paperwork for this bike other than a bill of sale, from MA.
    VT is the only route.
    To be clear:
    I'm not trying to make this into a nice dual sport. I'm trying to get it so I can actually ride the fucking thing. Closest legal place is in NH 40 minutes away now, for some glorified fire roads. Closest legal real trails are 1.5 hours away.
    Maybe I should just pick up a DR350 or some shit and rip that around all the unmaintained roads in my town.
    Suddenly the price tag you've mentioned in the past makes a lot more sense..
    That blows.
    Not the dumbest idea in the history of ideas. If I didn't want to ride hop-ev frequently I'd probably have dumped my 200 and kept my DRZ.
    To be clear:
    Don't you have some land living in Royalston? If not, should't you be able to buy land for like a hundred bucks an acre in Royalston? It's not cheating if it's your dog, man.
  22. #647
    I have 3 acres, working on an adjoining 3.
    The housing bubble has hit us too. 3 acres (min lot size) is going for $20-$35k even here now.
    Ahhhh, now it’s coming together for me... if you can still do it by mail, then give that a go. If you must bring the bike up for inspection prior, THEN you’re looking at having to get a full kit.
    Or sell it, and replace it with something with paperwork, and then just put a plate on it.
    Or keep it for the woods, and pick up a dual sport or 4, of different degrees of woods/street mix.
  24. #649
    3 acres is enough to have some fun on. Not tapping out 4th gear fun, but fun. Use your glorified lawn mower to make a rock garden, have some log crossings, perimeter trail can give you at least 1 or 2 decent straights, and a bunch of tight interconnecting loops. Biggest obstacle in getting to ride for dad-types is the amount of time it takes to load up, go somewhere and do it. If I couldn't gear up and ride straight out of my barn I probably wouldn't ride enough to justify keeping my bike. I'm not telling you anything you don't know already, am I?
  25. #650
    No, not saying anything new. I have quite an assortment of terrain to make some tight technical and varied runs around my property, but it's the time required to make the trails that's killin me.
    In all reality, I shouldn't of bought a bike. Just not enough time given all the projects I have going on and being a dad.
  1. Don't be a Dumb-Ass...like me!
    By sandros in forum Vermont Events
    Last Post: 09-22-10, 08:59 PM
  2. is it dumb...
    By newgixxerchic in forum General Bike Related
    Last Post: 05-15-08, 04:43 PM
