Results 1 to 17 of 17
MX207
    MX207
    The track is open. This weekend is a normal open practice weekend, weather looks to be crap on Saturday, Sunday could be viable.
    Next weekend is the 'ATV Jamboree' so expect quads both Saturday and Sunday. There will also be a roach coach on site providing food, pig roast, mud runs, drag races, etc. Could be good times, could be quad-fail. http://mx207.com/images/jamboree2011.pdf
    Wirelessly posted (Mozilla/5.0 (webOS/1.4.5; U; en-US) AppleWebKit/532.2 (KHTML, like Gecko) Version/1.0 Safari/532.2 Pre/1.0)
    did you get your fork fixed?
    Re: MX207
    Not yet, I know where there is a tool in Mass to do the job, I also just scored a good deal on a Helicoil kit on ebay (I like owning tools) for MUCH less than I initially feared. Should arrive Monday or Tuesday, which means my fork will be fixed that day. Saturday I'm hoping to finally sort the clutch if my lock-tab washers have arrived. At that point the WR's list of faults will be reduced to:
    - Purple seat, really?
    - Suspension could use some TLC/bushings/fluid
    - Seriously, a purple seat? What the hell?
    - I need to put washers on the radiator mounting bolts so they don't suck into the bushings
    - One radiator could stand to be 'tweaked' so I can stop using zip-ties on one shroud
    - My seat is purple, this is unacceptable. It's also got a couple small tears, so I can at least justify a new cover with a straight face.
    - I should take a stab at wiring up the headlight just so it looks more functional
    - I should time-sert the drain plug, the existing threads looked at me funny the other day
    Re: MX207
    Ha! I had to recover my blue/pink KDX seat to save face, so I know where you're at! I found a good quality cover on ebay pretty cheap.
    Re: MX207
    I'm game for MX207 this weekend, who's joining me?
    Re: MX207
    Whoa! Miracle of miracles... the WR is ready to rip! Congrats man. Enjoy it.
    Re: MX207
    nice werk does the sticker on the side plate say 'eBay Special'?
    this weather is killing me, both bikes are still down!
    Feb 2009
    Lost in constant migration
    Re: MX207
    Hey Josh,
    You may want to add the fact that your seat is PURPLE to your punchlist.
    Sincerely,
    DDK
    Re: MX207
    Quote Originally Posted by "Dangerous" Dan K View Post
    Noted. Just to clarify, a purple frame is good to go though, right?
    Feb 2009
    Re: MX207
    For sure. That's stylish. The seat is just silly.
    live to ride seth399's Avatar
    Feb 2007
    CA
    Re: MX207
    OMGZ, your bike is together??
    I want to go to 207 so bad but I don't think I can make it this weekend.
    LRRS #399
    MX #505
    Haverhill, MA
    Re: MX207
    Sweet the beast is running!
    Did you get your carburation issue that you were experiencing last year at Clough straightened out? Hope you did, I don't think your right leg can take all the kick starting you had to do that day.
    Re: MX207
    Had a ball at MX207 today. Riding plus pig roast plus watching quads and riders get buried in a mud hole was fun. What sealed the deal was the ice cream truck showing up at 3pm, then it was a PERFECT day.
    They've added a ton of sand to the track, it's much softer than I remember last year. Some of the turns were down right fluffy if you were ouside a beaten line. It also got beat up faster and worse than I ever recall seeing. A couple jump faces were very rutted by the afternoon. Still fun though, and I suspect a good primer for what I'm in for next month...
    The WR is up and running. Front brake is still dragging but I've got a fix on the way, a 2005 CRF250 brake system. I'm hoping a 13 year newer setup might behave a bit better? Rear brake is WAY too touchy, I need to lower the lever as I keep hitting it on landings and stalling the bike. Surprised the crap out of me the first time I did it. (Did I mention I'm getting both wheels off the ground now, at the same time even!) Jetting is close, but not perfect. Just off idle to 1/4 or so is hit or miss, sometimes it rips immediately, other times it chugs. More throttle and it'll light up so I suspect it's a pilot or needle issue at most. Restarts were no issue today, as long as I rolled the motor to just past TDC and gave it a good whack it'd light first kick nearly every time when warmed up. Cold it takes a couple plus choke to wake it up. The new gearing helped a ton also, I can crawl in 1st now. Clutch is also semi-cooperating as well.
    I've got house stuff to take care of so I won't be out Sunday, should find a weekend to get everyone around to play soon, now that I have a viable toy.
    Feb 2007
    CA
    Re: MX207
    nice dude! Can't wait to get up there. I am putting on my gas tank and random shit now to finally fire up my bike. I drove like 65 miles yesterday to find 5 gallons of VP
    LRRS #399
    MX #505
    Lifer lrrs313's Avatar
    Asheville, NC
    Re: MX207
    Congrats on getting the bike together and rideable (special consideration for doing it before Seth managed to get his much newer bike to the same condition). Now go ride the snot out of it so you can have the fun of breaking more stuff and fixing it again!
    And I'm really jealous of all of you that have dirty bikes right now. I'm really starting to jones for twisting throttles.
    -Brian
    15 S-Works Venge
    Feb 2007
    CA
    Re: MX207
    aha Kurlon cursed me. I finally put all my shit back on my frame today and put gas in the tank to finally break it in. Tank petcock starts dripping fuel so I had to drain it and get a new gasket for tank
    LRRS #399
    MX #505
    Re: MX207
    What?! How is that MY fault?! If it's my fault I want to be responsible for fixing it.
    And then registering it under my name, and riding the snot out of it.
  1. MX207 - 11/21
    By Kurlon in forum Dirty Bastards
    Last Post: 11-21-10, 09:17 PM
  2. mx207 Saturday
    By seth399 in forum Dirty Bastards
    Last Post: 07-11-10, 07:19 PM
  3. MX207 Sunday
    By FTMS in forum Dirty Bastards
    Last Post: 05-05-10, 06:15 AM
  4. mx207-- one last time?
    By lrrs313 in forum Dirty Bastards
    Last Post: 11-09-09, 09:44 AM
  5. mx207 maybe for last horrah
    Last Post: 10-20-09, 04:52 PM
