Results 1 to 19 of 19
Sidestand tightens up?
    Ok. Maybe im stupid. But wjy does my ktm side stand bolt get tighter with use until i can barely move the sidestand???.
    Lifer isaac_'s Avatar
    Jul 2014
    Central CT
    Re: Sidestand tightens up?
    Mine rattles apart and yours rattles itself tighter
    Never had that problem.
    I had the pivot fail while trying to kick the bike on ice.. harder than it sounds.
    Lifer ZX-12R's Avatar
    Candia, NH
    The mounting bolt on mine broke taking the flange on the frame with it. I ended up replacing it with a Pro Moto Billet model.
    Haverhill, MA
    Only reasons I can think of......
    Does sand/dirt get in between the pivot bolt and the kickstand arm and bind up the joint?
    Are the pivot bolt and the kickstand arm made of materials that gall over time due to the clearance between the two being too small and not lubricated?
    Bike wants you to keep riding. that is why it stick in the up position.
    Set it with red lock tight
    No lock nut on the back.....allows it to move a tad every time it goes up
    What confuses me is that it's not a bolt/nut design, so it is able to tighten up every time I put it down. I tried locktight to no avail. I think the sand makes it worse.
    Be a man. Use a tree.
    I'm not quite enough of a redneck that there are trees in my garage... and since it's a carport there are no walls either.
    Used to happen to my 525 exc and 200xcw, only thing that solved it for me was a shot of chain lube to the pivot point every time I lubed the chain.. which was before every ride.
    Wow, Ok, so it IS a stupid design. I thought I was just a monkey...
    Rookie Rada's Avatar
    Sep 2010
    Granville, NY
    IDK.
    Mine doesn't.. Then again I don't ride in sand either.
    IDK.
    So what are you saying?
    lol
    Too short to use a center stand haha?
    Yes
    Nov 2009
    Bristol County
    I've been having that problem lately too. Seems like it stiffens up and requires another spray almost every ride. Pretty sure it only started happening after the first time I got spray-happy and spritzed everything I could see. Been thinking maybe I should take it apart, clean thoroughly and stop lubing it.
    nedirtriders.com
    "It's not a bug. It's a feature"
    some people pay extra for it
  1. sidestand removal
    By woody9189 in forum Pit Area
    Last Post: 03-30-10, 09:10 PM
