Results 1 to 14 of 14
silicone hoses
    silicone hoses
    I put new silicone hoses on the 300. One of them is making contact with the expansion chamber on the exhaust. Should i be concerned about melting?
    Edit: according to the company these have a "working range or -60 - 260 degrees". I'm guessing the expansion chamber gets hotter than that.
    Nov 2009
    Bristol County
    Re: silicone hoses
    260F or C? Big difference. Probably F since I think that's the upper limit on most coolant temp gauges. Some silicone products are sold as oven safe, but I don't think all silicone is. I dunno what's typical for EGT's on a 2stroke dirtbike, but car EGT's are well beyond 260F.
    Was the previous rubber hose touching too? I'd assume not.
    nedirtriders.com
    Re: silicone hoses
    Cut a piece of the old one and wrap it and zip tie is what I did.....having a clearance issue that was the original culprit of a worn hose and dirt ate mine
    Re: silicone hoses
    how bad is the interference? if just resting on the pipe a bit, dent it in to create clearance. i've done this on multiple bikes in the past, works fine.
    also agree wrapping the hose with a piece of inner tube or another hose (if not too thick) adds some nice protection. if you let the two rub together it will wear a hole.
    Re: silicone hoses
    EGTs run EXTREMELY high in 2 strokes. there is no valve train to absorb any of it.
    Haverhill, MA
    Re: silicone hoses
    Forget about whether the hose can handle the temp and figure out and fix why they are touching in the first place. Pretty sure KTM didn't design it to have a hose resting on the exhaust pipe.
    Re: silicone hoses
    i dont recall. its all pretty tight through there. i also believe that the hoses may be a touch thicker than OEM
    its not pressing against it but its touching. id be concerned about wrapping the hose in another hose because it essentially just makes it even thicker and it will most definitely be pressing against the pipe then.
    i also will not be denting my brand new pipe for clearance lol
    i think its a combination of a thicker material and the aftermarket world be "close enough".
    im probably gonna try giving the hose a bit of twist to see if i can rotate it away from the pipe a bit.
    id take a pic but the camera on my phone has gone TU
    seems thats not my only issue either. i think my aftermarket radiators are a little thicker than stock as well. the hose that runs left to right around the head is getting pretty squished by the radiators into the head bolts. the radiators may also be a contributing factor to my hose/pipe interference. the spigot for that hose seems to be a little longer than OEM so i think its sending the hose down a little lower than originally designed.
    seems im gonna have to stay after work a couple nights this week to square this away...hopefully.
    Lifer Tekime's Avatar
    Mar 2016
    Falmouth, ME
    Re: silicone hoses
    If it's high temp silicone that range could certainly be celsius
    I use some silicone hose for the breather on my DR where it gets up to 300F+ and no hardening, melting or deformation
    Exhausts get frigging hot but if it's within the operating range of the material it should be ok. Not saying it's best to just leave it but...
    05GSXR75005SV65090DR350
    Re: silicone hoses
    Quote Originally Posted by Tekime View Post
    thats a fair point. especially from an over seas company. 260C would be 500F
    Re: silicone hoses
    i meant something thin for extra abrasion protection. pipes can get pushed in pretty easy after a wreck.
    on the dent, it's not a big deal depending on where the contact point is. here's one i did to clear the lower rad hose, they were touching before. brand new pipe, can't even tell it's not factory.
    Re: silicone hoses
    I wish you put this much effort into buying my trailer, Oxx.
    Re: silicone hoses
    I've got a couple precision, dyno tuned pipe adjustments on my sumo for oversized radiator clearance as well.
    You can buy a precision adjustment tool at the hardware store:silicone hoses-317-4w-fygl-jpg
    Re: silicone hoses
    I had a clearance issue w/ a silicone hose on a header on my V4 Honda. Had to rotate it out a bit, use a section of old hose and a hose clamp around it all. I then had the hose clamp (where the adjuster is) that was making contact with the pipe. I am sure the hose clamp got hot, but it stopped the hose melting underneath which had been occurring prior.
    Also, that self-sealing coolant hose tape is the balls.
    CCS/LRRS #83
    Re: silicone hoses
    Link and/or description? To the tape, not the balls.
  1. 07 zx10r Tokico calipers and pads and hoses, practically unused - Free
    By juha_teuvonnen in forum One Man's Garbage...
    Last Post: 08-12-18, 07:09 PM
  2. Hoses coming from SV tank
    By Petorius in forum Bike Maintenance
    Last Post: 04-29-16, 05:56 AM
  3. Replies: 1
    Last Post: 01-10-10, 07:36 PM
  4. Silicone (Not the bewbies kind)
    Last Post: 04-03-09, 05:37 PM
