Results 1 to 23 of 23
Tire mounting tips???
    Lifer McBiggity's Avatar
    May 2003
    Charlton, MA
    On how not to pinch a tube. Pinched the original, now did the same to the replacement. I am going to buy stock in tubes.
    But I am getting good at getting the tire on and off the rim, lol.
    Lifer Pittenger5's Avatar
    Austin
    Re: Tire mounting tips???
    Ha, I just went through 4 tubes. On one wheel, the other ones Ive done, no problems.
    Zip Tie Alley #505
    May 2003
    Charlton, MA
    this is just on the rear. Haven't even started the front. I am buying a pallet of tubes tomorrow.
    LRRS EX #99 Kitt's Avatar
    Lake Champlain, VT
    for tubes, I put one bead on the rim, put the tube and rimlock in, then inflate it slightly just to keep it from folding over on itself (so I know it's there before it gets pinched). Then, I use 3 irons to put it back on...
    I just got a mojo lever in the mail today actually, haven't even taken it out yet!
    Lifer gixxer72's Avatar
    The desert
    A little air in the tube to help keep its shape is key. Some powder on the tube and using the heavy duty tubes will also help.
    May 2003
    Charlton, MA
    well, will let ya all know how round 3 goes tomorrow. haha
    live to ride seth399's Avatar
    Feb 2007
    CA
    ya def. put alittle air in the tube! Also, you are probably pinching tubes by inserting the levers too far under the tire bead. Be careful on how far you insert them and you will have better luck. Spray the entire rim/bead area with soap/water or windex to lube it as well.
    LRRS #399
    MX #505
    I pinched one this on saturday. Tire irons for sure. I also had no luck getting my 19" rear tire off the rim. It has 2 rimlocks, and seemed impossible. What's the trick?
    Feb 2007
    CA
    2 rimlocks? that is nuts, I never knew any wheels would be like that...did you try using the levers really close to each other so you weren't taking large bites? I do find in general that I can change fronts much easier than rears.
    LRRS #399
    MX #505
    Yeah, We were bending the big irons even with small bites.
    Feb 2007
    CA
    wow, hacksaw that shit! aha
    LRRS #399
    MX #505
    May 2003
    Charlton, MA
    sawzall?
    Waterbury, VT
    With 2 rim locks - loosen the nuts as much as possible, and make sure both beads are broken completely free of the wheel and the rim locks will move in and out easily (they can get seized to the rim, tube, and tire). Lube everything up. Start the levers on either side of a rim lock - this should let the other side slide into the valley of the rim. Once you figure the tricks out - it's not a matter of strength.
    SSearchVT
    Lifer Ken C's Avatar
    Sep 2001
    Western MA
    I was helping Paul with his tires. I've done a lot of tires and that rear was not budging even with all my tricks. I said the same thing, "TWO rim locks?".
    We moved on to the front. Had it 99% on when I had to use the thin iron, which has a sharper edge and I caught the tube. The other advantage to having a bit of air in the tube is that you know when you popped it. Pssssssss.
    Worcester, MA
    going to have to remember not to puncture a tire if i am out riding with mike.
    LRRS EX #165 (formerly)
    Northampton, MA
    Trick is to bring it to my house with a large pizza and a 6 pack. You'll come home with a set of mounted tires that hold air, a stomach full of pizza and 4 beers.
    Worcester, MA
    haha. more than a six pack after that drive.
    does that make you a 2 beer queer??
    Northampton, MA
    That makes me someone who will change your tires for pizza and a couple beers. Sorry, no man-sex here. Keep looking elsewhere
    May 2003
    Charlton, MA
    went out and bought 4 tubes. 2 front/2 rear.
    Got the rear tire done with the first tube with no problems.
    Then did the front, 20 minutes later, finished and still with the original tube on the front. Now I have 3 spare tubes, lol.
    Worcester, MA
    Quote Originally Posted by McBiggity View Post
    practice makes perfect.
    KB KB's Avatar
    Manchester NH
    Practice does make perfect.
    LRRS/CCS EX #13
    GMD COMPUTRACK
    Lifer eboos's Avatar
    I use dish soap on the tire, and I put a little air in the tube. I use 2 tire levers and my foot to hold the other end down. I haven't pinched any tubes on either MX or SM wheels. I've only done 3 sets of MX wheels though.
    I once mounted a SM front tire on my 125 using plastic bicycle tire levers. I was sweating my ass off, and it took forever, but it worked and I didn't brake the lever.
  1. Easy tire mounting
    Last Post: 12-19-11, 10:40 PM
  2. tire mounting/balancing
    By darkduc7 in forum Vermont Events
    Last Post: 06-21-10, 09:15 PM
  3. Tire Mounting
    By JonT in forum General Bike Related
    Last Post: 06-09-10, 04:05 AM
  4. tire mounting
    By PPS26 in forum General Bike Related
    Last Post: 01-27-10, 01:39 PM
  5. Tire Mounting CT
    By VenomXX in forum Bike Maintenance
    Last Post: 03-10-07, 03:31 PM
