Results 1 to 16 of 16
Downed trees
    Lifer Pittenger5's Avatar
    Austin
    Downed trees
    How the fuck do you deal with downed trees that are at like a 45 degrees angle across a trail? Not talking about big motherfuckers either, just normal slippery as fucking trees. Seems no matter what I try to do my bike kicks so hard I gotta put my foot down to keep the bike up. Both front and rear depending on how I hit it.
    Zip Tie Alley #505
    Jan 2007
    Rochester MA
    Re: Downed trees
    Chainsaw.
    LRRS EX #99 Kitt's Avatar
    Lake Champlain, VT
    Re: Downed trees
    This is what I do:
    approach it as perpendicularly as I can, lighten the front end (blip - little to no negative effect), transfer weight forward quickly before rear tire hits and the "side kick" will be reduced somewhat.
    Get a trials bike, it will help! KLX 110 + $2400 gets a nice 06 gas-gas!
    Re: Downed trees
    Slippery ones at a 45 are tough. You need to get the front wheel over, or at least kiss it on top of the tree. Squeeze the bike with your knees and pretend you are going to bunny hop over it. Even though you can't bunny hop a motorcycle, that technique will let the rear wheel get over without sliding down the log too far. You need to have rolled off the gas as you unweight the back of the bike.
    Oct 2008
    Albany, ny
    Re: Downed trees
    American loggers sugest primacord and or several sticks of high explosives.
    Make sure you use enough so you don't have to do it a second time. And most important, use a long fuse, lite it , and run really fast.
    Away from tree
    Beat It Like A Rented Mule !!
    Legend in my own mind
    Austin
    Re: Downed trees
    Ha, KLX + some moneys = TTR125 for Leeza, plus, no new bikes till we have space for them.
    Zip Tie Alley #505
    Re: Downed trees
    Drop one tooth on the the front Sprocket.
    You will be able to loft the front over them and transfer weight to the front Lots of throttle lots of momentum,
    Zip Tie Alley Racing #444
    Signature edit by Tricky mike
    Lifer slammp's Avatar
    Jul 2008
    Massachusetts
    Re: Downed trees
    On my iPhone I can do a double backflip over them - should transfer to real life right?
    Re: Downed trees
    This is what I do:
    Yep... exactly what I do.
    The only thing I'll add is that I will look for a rock or something before the tree that can help me unweight the back tire first. Basically, I will attempt to "jump" the down tree by doing a bunny hop type jump starting before it.
    Ideally the item you use is less than your wheelbase away from the tree. So you pre-weight the suspension and then hit that "item" which should let you get both tires airborne ... when your front tire passes the downed tree, push weight forward and down on bars, and your back tire should clear the tree completely... or at least skim the top with no ill effects. (assuming you can't easily just jump the entire log)
    If I can't pre hop the log, I slow down a lot due to the risk vs benefit thing.
    I'm not racing so going fast doesn't matter, but the type of crash that could result is pretty nasty.
    The back end usually slides quickly and violently to one side... enough that you're sent over the high side pretty quickly.
    Tony
    Trackdays in CT, NY, and NH
    www.TonysTrackDays.com
    Central MA
    Re: Downed trees
    Another method is to scan the very edges of the trail. The log/tree is often closer to the ground there, with more bark left on it. You can often use the edge/embankment to jump right over the log.
    As mentioned here, if the log is laying in this direction / swing to the right, and turn quickly to the left to cross the log as perpendicularly as possible - if you can not use the edge method. Often, a combination of pre-jumping, edge riding, and attack angle can be used.
    so/so mechanic... NeverlosT's Avatar
    Jul 2008
    South Kingstown, RI
    Re: Downed trees
    if the log has no bark or smooth bark and is wet you better jump all the way over or you are f-ed. some bark or not a full 45 deg angle and you are in there.
    mountain biking is easier, you just bunnyhop that bad boy.
    Don't Fake the funk on a nasty dunk.
    NEW STREET/TRACK: 2007.5 Aprilia Tuono
    STREET/TRACK: '08 CBR600RR (SOLD)
    '07 VFR800 (SOLD)
    Central MA
    Re: Downed trees
    tons of good stuff in Shanes DirtWise DVD, highly recommended
    Re: Downed trees
    I take a non technical approach to those types of trees. When I get close, I twist the throttle and close my eyes...when I open my eyes, i'm either on the ground or continuing on my way. It's a 50/50 shot sometimes, but keeps things exciting.
    Re: Downed trees
    shane watts is sick though!
    here's another option: I had a harsh riding MX bike that kicked my ass all the time anyways, with its stiff suspension and light-switch like power delivery...so what I did was just downshift, get it into the top of the power curve, stand up, lean back while pulling on the bars, and let the bike buck wherever it wanted to, hoping that the forward momentum was enough to keep it going straight
    surprisingly, staying pinned on a 2-stroke MX bike is the fastest way that I got over the hardest obstacles
    Dec 2003
    Ma
    Re: Downed trees
    This and don't be on any power when the rear wheel goes over it. Have the momentum before you hit it.
  1. snow+leaves on trees
    By burnham in forum Off-Topic
    Last Post: 01-08-12, 08:44 PM
  2. In my day we had duct tape and trees
    By idratherberidin in forum Off-Topic
    Last Post: 05-21-10, 02:20 PM
  3. My riding is done for a while trees hurt
    By Cmorsch in forum General Bike Related
    Last Post: 10-05-09, 08:35 AM
  4. Onions and Xmas trees....
    By MissTwisties in forum Off-Topic
    Last Post: 12-12-06, 11:08 AM
  5. Anyone is equipped to cut down/trim trees in here?
    Last Post: 04-15-04, 09:20 PM
