Werd... gonna try & make it one of the days this weekend. We'll see.
No guarantees but I'll try to make 101 Sunday, I have a care package for the Squirrel...
O that place is too ....F
NO! but if you want them to spin for some reason and feel like changing them, I just use sockets that fit the OD of the bearing but still fit in the hub and use a threaded rod with washers on it as a shitty makeshift bearing puller. I built it with crap from home depot.
LRRS #399
MX #505
They should move without any binding or rough spots. Aka, you're due.
Set the wheel on a table on blocks such that the hub is directly supported and there is room for the bearing to drop out when it's ready. Use a socket sized to match the OD of the bearing on one side as a drift and tap the bearing 'into' the hub a couple times smartly. The hope is the shock will transfer from the bearing, down through the spacer into the other bearing, giving you some clearance. You can then shift the internal spacer around a bit to use as a drift against the lower bearing. Tap'er free, flip, and use a drift against the remaining bearing directly.
Wait, you should know this already?
You could always use my other technique... start with hammered to death 1992 wheels. Tip wheel to one side to remove bearing that managed to stay in, remove other bearing off floor that fell out when you took the axle out. Install new bearings by wrapping with feeler strips till snug.
In other news, given the weather, I think I may wuss out on MX101 Sunday. Not interested in a cold mudder session.
Soooooo... MX101 tomorrow? What time?
Sunday's gonna be awfully 'white'... you guys still goin?![]()
Wirelessly posted (BlackBerry9700/5.0.0.979 Profile/MIDP-2.1 Configuration/CLDC-1.1 VendorID/102)
K. Well lemme know once u find out. I still gotta load up.
guess crow hill got about 22", the mountain got 18-20" and we got about 15" down the road a bit.
wonder what this will do for the season.
