Results 1 to 10 of 10
14 HP DOES make a difference...
    May 2007
    Southern NH
    Took the new Multi to Seacoast this morning to try and sort out why the HP was down compared to 2 others Dynoed the same day. Giles and Rob both dynoed around 131. My came out at 114.
    I'm not sure exactly what was done...something about 'balancing the cylinders'. They also replaced a thermostat so the right temperature range was reported to the ECU. Result was 128.45 avg over 3 passes.
    Without reporting details...Riding home was way fun. Was definately noticable. Or at least, it was in my mind...!!!
    Thanks guys...
    Muhammad Ali.
    Lifer R1's Avatar
    Somewhere you dont know...
    Re: 14 HP DOES make a difference...
    You're Much Welcome...
    Lifer Kenn157's Avatar
    Saddlebrooke AZ
    Good to hear Dave! Bet thats a load off your mind!
    ...and here I was about to guess that they didn't take it to the redline....much the same reason why my '08 FZ1 dynoed 22hp less than the others.
    May 2007
    Southern NH
    ...and....before anyone else says it...
    I know...I'll never use all that power...!!!
    Muhammad Ali.
    Lifer R1's Avatar
    you should give it to me then....
    I will use it...
    Lifer wiggeywackyo's Avatar
    Feb 2009
    City
    Throttle bodies needed balancing?
    LRRS 878 Clapped out Gixxah
    Throttle body balance?
    Lifer Stromper's Avatar
    Eastern Ct
    Throttle body synchronization but yeh balance
    same deal equal vacuum and bad thermostat may have triggered some sort of go home map
    Lifer Danz19899's Avatar
    Grafton, Ma
    a balanced engine is a happy engine
    www.bostonmoto.com
    Ride to live, live to ride
  1. What's the difference?
    By R7 in forum Bike Maintenance
    Last Post: 07-27-09, 09:30 AM
  2. Can you tell the difference?
    Last Post: 01-27-07, 11:54 PM
  3. What's the Difference?
    By TourModified28 in forum General Bike Related
    Last Post: 04-28-03, 05:39 PM
