Page 9 of 14 FirstFirst 1234567891011121314 LastLast
Results 201 to 225 of 348
2007 Suzuki Vstrom 650 - breakdirt916
  1. #201
    Lifer Stromper's Avatar
    Eastern Ct
    Re: 2007 Suzuki Vstrom 650 - breakdirt916
    Yamaha #4 sealant
    Threebond
    Both oil proof elastic goo
    also Oil is cheap
    The calculus of hate
  2. #202
    Jamnuts jhawley's Avatar
    Oct 2009
    Southern CT
    Real Story here is whats your snapchat. this pics are hysterical.
    Power washed the bike, bla bla bla bla, now the FI light is on.
    That's all I read, and that's all you should read too, Bhavesh. I'm betting your issue is something related to the above sentence.
    Eastern Ct
    Suzi's have very sh*ty connectors easy to corrode
    Dy bike expose to heater
    unplug plug unplug every connector , clean if you see deposits, spray with dielectric grease
  5. #205
    the FI light is intermittent...unfortunately strom troopers recommends that you address intermittent right away...I will have to dig up the extra key and bring a jumper so I can read the code in dealer mode. Bike will stay parked today for the Yamabond to cure
    I took the stator cover off for the hundredth time...luckily the new gasket I put on did not stick/tear apart upon removal after 1 day of riding. I cleaned everything up and inspected the grommet where the stator wiring goes through and did notice it was a little loose in the stator cover. It didn't take much wiggling to make a small gap around the grommet; so to cover all my bases, I put yamabond between the grommet and the stator cover; re-installed it the grommet, smeared Yamabond around the border of the grommet, placed another bead where it contacts the gasket, then put yamabond on the whole gasket before re-assembling everything.
    It takes 24 hours to cure properly...so here comes the waiting game before testing...
    Was looking at the microfiche for the front wheel - I need an oil seal before I can do the wheel bearings
    oh well...I needed a bunch of fasteners and bar end/handguard parts anyways...
    Need to sort these issues before I do any real touring...what a bummer to buy a touring bike that I trust only for short distances...I guess that's what happens when you buy a 10 year old mid-mileage (27,000) bike used that will need maintenance as the mileage creeps up. Might be easier to just rent one for a couple days The AT was just over a hundred bucks a day!
    Quote Originally Posted by jhawley View Post
    @cali2smoke
  6. #206
    Yamabond on a zuk, won't work
  7. #207
    It worked! Got to work and no drips
    No more embarrassment that my ish leaking when parking bike
    One problem fixed...but that front wheel bearing needs to be done yesterday...it is howling like a wolf...seal should be here tomorrow
  8. #208
    Shouldn't the All-Balls kit have all the seals with the bearings?
    They might...
    I, of course did not take the advice you have provided over and over... instead I googled it and found from Strom troopers that the bearings are a standard size, and that you can buy it from a local bearing supply store...so that's what I did...at roughly $8/bearing ish. Advantage? Probably none...so here I am without a seal
  10. #210
    Don’t trust that forum.
    The All Balls kit, with two bearings and two seals, is $13.06 shipped free on Amazon.
    I think the seal alone from 'zuki was $15
    faiiiillllllllllllllll
    good news is I haven't seen the FI light on...hopefully it stays that way and I can continue to get maintenance done...fresh tires are begging for some canyons or touring rides...
    forks + steering head bearings are what I really want next...bike still has a super slight shimmy in the bars over white painted lines or cracks
    still thinking of selling by this summer...nhbubba said variety is the spice of life...so I'm sure I can find another ugly/low-theft ~$2k bike (triumph sprint? suzuki bandit? sv1000?) that can handle a top case which can fit a helmet + jacket...or maybe switch to a meyers manx buggy so I can off-road with it + surf boards on a roof rack
  13. #213
    Eastern Ct
    DL1000 have sealed bearing but no separate seals
    Unfortunately it is VERY hard to know you have better bearings now a days
    I would say that All Balls are probably Chinese but so probably is everything else
  14. #214
    I would just go OEM...
  15. #215
    I'm racing on All Balls? Can't say I've had any failures with them.
    I hear that some motorcycles are made on an island right off the coast of China. Junk.
    front wheel bearings done...rear next
    I usually have to run out and buy a tool or two for each service I do...this bike needed a 12mm allen key for the front axle
    that's the only thing I bought
    did not have a front wheel stand, so I made do with a single hydraulic jack under the left fork leg, while on the kick stand, and handlebar ratcheted to the left. Dangerous? maybe...it worked. Bike sits pretty far over to the left on the stand.
    Removed the seal and tapped out the bearings with a punch...to be honest, I could not tell they were damaged.
    They did not have any play in them, and they spun (greased up and) freely. As I linked before, that's a GREAT THING. If the bearing was damaged enough that it bent/scored/warped/affected the wheel "dish" it was fitted into, then I'd have to get a new front wheel.
    New bearings are a little different - sealed on both sides. Better? worse? I dunno...they fit nice and snug. Hopefully the 2nd seal doesn't tear out and damage the bearing
    I had a terrible time trying the freeze/heat/drop in method on the RM125 crank bearings, so I'm always a little uneasy installing them. Froze the new ones, greased all surfaces, used a large socket (finally had the right size laying around!! did not have to buy a spare!) on the outer race and tapped them in a circular pattern in until they were all the way in, and visually even. Had to ratchet the 2nd fork leg to line up with the one under the jack, then got everything back in.
    First test ride - tons of traffic
    15 mins later, finally got to an open stretch and up past 40 - the whistling/howling is goneeeeeeeeeeee!!!!!
    Real test is on a work day...those are the only days that things *really* go very wrong.
    Tightening everything up right now.
  18. #218
    Remember, you can't test bearings without putting them under load. They may look fine, free spin fine, but be shite.
    Eastern Ct
    My front axle tool is the head of a 8mm (i think) class 5 bolt that I grip the shank with big vise grip
    I think it cost me like $2.50 at local hardware
    Vise grip savage but will remove the rear axle nut too if need be
  20. #220
    Just put a nut on the bolt and use a wrench. Still have one around somewhere.
  21. #221
    I just bought a 12mm allen key w' a 3/8" drive hook up...threw it in my bike's toolkit under the seat
    but as usual, Kurlon was right...rode to work today...aaaaand the sound is (different, but) still there
    it kind of sounds like a "whirring" sound that's intermittent, but usually above 40mph, but disappears above 80 (indicated). Started off as an intermittent chirping sound, then turned into a whistling, and after the wheel bearing change (that...could I have messed up?) is now more like a jetson's spaceship. I dunno. May just focus on the forks and steering head bearings for now. WOT speed wobble over painted lines at 90-115 indicated is scary
    Also - I've been having SO MUCH DARN FUN on new tires, that this happened:
    Tires for me are like laptops - don't pay top $$ for the latest/greatest/top tech. Just buy (cheap) new, and buy often. My newest tires are always better than used expensive ones...skinko all the way.
    Getting close to 1,000 miles on the new rear in a couple weeks...guessing that leaves me about 2-3 months of fun before they start to square off. So new goal: I'd like to get more miles on the *sides* of the ties before I square it off. Try canyons. Day trip it and spend a day around Palomar. Don't just commute for months.
  22. #222
    Eastern Ct
    I measured my front axle removal bolt
    Surprisingly it is an American 1/2 by 13 bolt available at any hardware
    Yes most use 2 nuts against each other and an adjustable wrench, I also carry tire plugging kit and Walmart slime compressor
    Used 2 times and everything worked
    I buy a new tire plugger refill cords because I worry about them aging, so far (knock on wood) they went in and lasted
    the life of the tire
  23. #223
    ^^ all of the above
    going to need all that when I start touring with it...also thinking of a battery jumper pack
    so this pic just surfaced
    back when I rode a 600
    10 years with her...such a lovely machine...life was (and is still) good...not sure I'd own an inline 4 sport bike again though
  24. #224
    I just read this whole thread.
    Thrilling content.
  25. #225
    Consistent with the bike
  1. For Sale - Motorcycles | 2007 Suzuki GZ 250
    By PurplePackage in forum For Sale
    Last Post: 10-18-20, 11:21 AM
  2. 2001 Suzuki GSX1300R Hayabusa - breakdirt916
    Last Post: 04-10-19, 11:40 AM
  3. For Sale - Motorcycles | For Sale 2005 Suzuki DL1000 VStrom
    Last Post: 10-18-18, 02:46 PM
  4. For Sale - Motorcycles | 2007 Suzuki GSX-R 600
    By frenchy21 in forum For Sale
    Last Post: 08-27-15, 06:45 PM
  5. For Sale - Motorcycles | 2003 Suzuki Vstrom 1000 with SV1000 engine
    By superbikejunkie in forum For Sale
    Last Post: 03-31-14, 09:37 PM
