Results 1 to 25 of 29
32mm Hex??
    32mm Hex??
    Are any of the axle keys 32mm??? Apparently I need one for the STM slipper clutch install.
    Jun 2005
    Re: 32mm Hex??
    For serious?
    Hmmm.. The Motion Pro tool everyone seems to have only goes to 24. 32 is big, son.
    Re: 32mm Hex??
    Yeah, Some have modded a bottom bracket tool from the bike world...
    Jun 2005
    Re: 32mm Hex??
    That's not a bad idea. I just measured my Park BBT-22 and it's 32mm:
    http://www.parktool.com/product/bott...et-tool-bbt-22
    Re: 32mm Hex??
    That's the one! Whack those splines off and send it to me???
    Jun 2005
    Re: 32mm Hex??
    I'd be happy to if you want to do an exchange. Send me a new one and this one's yours.
    Re: 32mm Hex??
    Sure.
    Jun 2005
    Re: 32mm Hex??
    Sure.
    Cool. PM me your addy and I'll get it in the mail. USPS cool?
    Jun 2005
    Re: 32mm Hex??
    Who loves ya, buddy?
    Re: 32mm Hex??
    You're the man! What does the other end look like???
    Jun 2005
    Re: 32mm Hex??
    3/8 drive
    Rookie Rada's Avatar
    Sep 2010
    Granville, NY
    Re: 32mm Hex??
    It's nice to be able to cut metal!!!!
    Re: 32mm Hex??
    Can you weld a banana to it for me, Tricky?
    Lifer SprintPoser's Avatar
    Apr 2002
    Central MA
    Re: 32mm Hex??
    I would have made you a tool for free Paul. Always just ping me if you need a special tool. I have lots of stock, tooling and machinery, love to help fellow riders.
    You should see the axles, nuts and other bits I've been making for Neil H (expat) for his 2 two-stroke projects bikes, all 316 stainless steel. I could post pix if you'd like.
    Re: 32mm Hex??
    Hey, Ken, I forgot you were out there. Nice offer. You've always helped me out in the past. I don't think the bottom bracket tool is expensive to replace, so no worries there.
    Cheers
    Re: 32mm Hex??
    Oh really... I may have to talk to you about my TTR...
    Apr 2002
    Central MA
    Re: 32mm Hex??
    Contact me via PM or e-mail.
    Here's a couple photos of some of the parts I'd recently made for Neil.
    Old stock ones next to the new stainless steel:
    A bit closer:
    Finishing touches on the heads, the original ones were done via mass production cold header operation so I couldn't exactly duplicate, but came really close. He likes the little chamfer around the hex better than rounded-off look of the stock ones.
    Close-up of an M14x1.5 6H thread, done with one turn of pullout so there would be no relief groove as a stress riser.
    Bunch of SS washers.
    A spacer for one of the axles:
    Recently modified one of his OE wheels to accept a different type of (right angle) Schraeder valve:
    I'm just need cost of materials and perishable tooling covered for small personal projects. If trying to develop a commercial product, we'd have to talk.
    Posting Freak Tas's Avatar
    Sep 2013
    Jaffrey NH
    Re: 32mm Hex??
    Nice looking products you got there.
    2004 SV650
    1979 GS 850GN
    2005 Tt-r125
    Re: 32mm Hex??
    That is some EXCELLENT work. Right now my goals are strictly personal, but that's not to say I don't have ideas that could sell... I'll put some notes together and PM you.
    Re: 32mm Hex??
    Wow those look awesome. 316 is a pain in the ass to work with.
    Apr 2002
    Central MA
    Re: 32mm Hex??
    Thanks guys.
    I've worked with 316SS for over 30 years so I've got a pretty good handle on it. What you see isn't the hardest of the work. I also make some larger diameter front axles (putting a GSX-R front end on an RZ350) and the challenge of making 12mm and 20mm holes through up to 12" of length was more of an issue. I my days of working in a shop it was a no-brainer with high-pressure coolant-thru spindles and solid carbide coolant fed drills up to 30xD deep. In my home shop I'm limited to flood coolant and extra-length parabolic flute HSS-Co drills and lots of peck cycle.
    I got it done though, trying to find photos of them.
    Re: 32mm Hex??
    Is it 316L?
    #331 CBR929RE's Avatar
    Bridgewater, MA
    Re: 32mm Hex??
    316 sucks
    Apr 2002
    Central MA
    Re: 32mm Hex??
    Is it 316L?
    Regular 316 as far as I know. Neil supplied it.
    CBR929,
    Sucks in what way? It is very corrosion resistant and polishes up better than 303. I've got all carbide insert and solid carbide tooling for turning and milling so it's cake for me. Even when I have to drill it I've got TiAlN coated HSS-Co drills that work great. Having all the years of experience with it makes for no problems machining it.
    Sep 2010
    Granville, NY
    Re: 32mm Hex??
    CBR929,
    Experience goes a long long way!!!
