Results 1 to 10 of 10
Adjustable foot pegs on an 08 gsxr 600
    So everyone has told me that the bike has adjustable foot pegs, but how do i adjust them???
    Jun 2005
    Re: Adjustable foot pegs on an 08 gsxr 600
    Welcome to the forum!
    Old and Slow Sheppo's Avatar
    Westford, Ma
    with an adjustable wrench...
    Posted by Jane in BoxChat
    what are you trying to adjust
    Wirelessly posted (BlackBerry8530/5.0.0.508 Profile/MIDP-2.1 Configuration/CLDC-1.1 VendorID/105)
    Ok. Now for an answer. If you remove thew two big allen head bolts from the rearset bracket, you will see a bunch of holes behind the bracket, drilled into the frame. These are alternative mounting points. This gives you your adjustment.
    Posting Freak senecak19's Avatar
    Massachusetts
    If its anything like the 06-07 the actual shift lever should be adjustable too (not just the rearset).
    Quote Originally Posted by senecak19
    Well that's the same on every bike made since the dawn of time.
    Infected Slyder's Avatar
    Concord, NH
    Kinda sorta almost. There is a plate with 3 drilled / tapped holes. This plate is bolted to the frame. The rearset is bolted to the plate. The 3 different holes are the only 3 adjustments you have on the OEM rearsets. Not too adjustable. The pegs come stock in the higher forward position. From stock you could move them down about half an inch (roughly) or back the same amount. If you move the pegs back, use the longer shift rod that comes with the bike. If the pegs are back and you move them forward...shorter shift rod.
    LRRS EX #99 Kitt's Avatar
    Lake Champlain, VT
    not the shift lever's pivot point. Which is critical for adjustable rearsets.
    Gear shift levers are either directly attached to the motor via a spline shaft which is an adjustable pivot, or directly attached to the footpeg mount and attached to the motor via a shift rod, again an adjustible pivot.
  1. For Sale - Parts & Tools | 00-05 GSXR CNC Adjustable Rearsets: Brand New $175
    By Davesavvy in forum For Sale
    Last Post: 03-26-14, 04:11 PM
  2. comp werkes gp foot pegs, or just replace the stockers?
    By DaveZX6r in forum Bike Maintenance
    Last Post: 09-09-12, 02:37 PM
  3. foot pegs ....rear sets , old beat busted?
    By Gr8lite in forum Wanted
    Last Post: 04-17-10, 06:27 PM
  4. Foot pegs
    By obsolete in forum General Bike Related
    Last Post: 03-01-09, 05:17 PM
  5. Foot Pegs
    By NashuaMatt in forum Bike Maintenance
    Last Post: 05-08-08, 10:55 PM
