Results 1 to 16 of 16
Any advice???
    Senior Member Legion1440's Avatar
    Medford, MA
    Any advice???
    My headlight went out the other day, so I bought a new one and tried to replace it yesterday. As it turns out, there must have been a short and the connector melted. Does anyone know if I can just buy the headlight connector, or if I'm stuck getting a new wiring harness? Been looking around a little bit online, but haven't found a definite answer yet.
    EDIT: 2000 Honda F4
    Re: Any advice???
    Buy a used harness off ebay and Hack it up.....cut off what you need and if possible Sodier all the wires and the wrap with tape.....
    Should be No prob.....
    Lifer obsolete's Avatar
    Norf Sho
    Re: Any advice???
    Junk yard / dealership or brake out the soldering iron and make one. :-)
    -Alex
    Re: Any advice???
    Yea what he said......LOLOL
    Southern, NH
    Re: Any advice???
    Separate high beam bulb so you can still ride?
    Cabin Fever kb1's Avatar
    Dec 2008
    Down South
    Re: Any advice???
    new wiring harness...
    Re: Any advice???
    As has been suggested, junk yard, cut the pigtail off, solder to your harness. I like to use heat shrink instead of tape, seals better.
    Before you install, clean the connector so the pins are nice and shiny, then pack it with dielectric grease. Normally it's corrosion upping the resistance that causes them to melt like that rather than a direct short.
    Norf Sho
    Re: Any advice???
    Not to much dielectric grease. :-) I learned that on spark plug wires.
    What kulron said. Buying a new harness is WAY more then you should spend.
    -Alex
    Majer:Danjer™ ChicknStripEatr's Avatar
    Sep 2005
    RI/NH
    Re: Any advice???
    I had to replace the socket on my bike, bought one from Advance Auto Parts for like $7. Solder and tape.
    Lifer Jayspeed's Avatar
    Medford, MA.
    Re: Any advice???
    Does the connector plug directly into the headlight or is there some wires hanging off the headlight with another connector? If so you might be able to find any type of weatherproof connector combo, both male and female, that can connect a number of wires. If you need 1 specific connector, can't a dealer order 1 for you?
    Jay
    2013 gixxer 750
    2009 Ducati M1100s
    2017 KTM exc-f 350
    Medford, MA
    Re: Any advice???
    I wish....stupid single bulb
    Medford, MA
    Re: Any advice???
    Thanks everyone. It turns out that I can get just the sub-harness that connects to the headlights and front blinkers....all for the fantastic price of $18.00. Ordered it today, should be in Wednesday. Looks like I'll have to use my bro's V-Star this weekend cuz it looks like it is going to be a good one.
    In hibernation
    Manchester, NH
    Re: Any advice???
    Quote Originally Posted by Legion1440 View Post
    Thats what you get for riding a Honda... Me and Bill will wave to you as we ride by on the GSX-R's
    Medford, MA
    Re: Any advice???
    Quote Originally Posted by FlynGSXR1k View Post
    Keep it up fool....
    Mike
    South Shore Ma
    Re: Any advice???
    EDIT: 2000 Honda F4
    http://images.search.yahoo.com/image...sigb=12sit5sfh
    Go to ADAP or any other auto parts store and get an "H4" connector and splice it in. Most bikes use an H4 connector if it looks like the one in the link you are all set
    Mike
    Raymond NH
    Re: Any advice???
    If the bulb is higher wattage than OEM, it will melt the OEM plug. Any chance it's not a stock bulb in there? You can get H4s up to 100/130 watt. That's about double the wattage of stock. If you run one of those, you should use a high heat connector. They are cheap. I think NAPA stocks them.
  1. Need some Advice
    By OC_R6 in forum General Bike Related
    Last Post: 10-17-10, 01:45 PM
  2. Need help/advice
    By Wishbone in forum Bike Maintenance
    Last Post: 11-20-07, 05:06 PM
  3. Need some advice on a possible buy
    By robogymnast in forum General Bike Related
    Last Post: 06-25-07, 10:08 PM
