Results 1 to 23 of 23
My Afternoon Project...
    Why Lie? It Was Me.... HO-HUM-R1's Avatar
    Aug 2011
    North Shore Ma
    Had a little free time this afternoon so i decided to go ahead and do my 520 conversion chain and sprockets.. went down 2 in the front and down 1 in the rear. Before anyone asks why I went with that combination, it provides the same gearing step as -1/+2 but it also extends the wheelbase by an inch or so due to the smaller sprockets. Makes the bike less wheelie prone with the steeper gearing. Although on my test ride it was pulling the wheel in 2nd and making it very light in third.. I'm sure if there was any less than 230lbs tucked over the tank it would have been crazy...
    2006 Yamaha R1, Graves Full Exhaust, BST Carbon Fiber Wheels, K&N Air Filter, EGR Blockoffs, Factory Pro Velocity Stacks, Power Commander 5, Stealth 520 Conversion -1/+1, FP levers, Ohlins shock, Ohlins fg327 forks, Ohlins steering damper, Sato racing rearsets, Goodridge SS shadow brakelines, EBC Extreme pads, Braking SK wave rotors F&R. few other appearance mods.
    Banned G21forme's Avatar
    Lakes
    Re: My Afternoon Project...
    Those anniversary graphics are delicious.
    That chain looks too tight.
    Lifer 03Worc9R's Avatar
    Worcester, MA
    Nice bike. How fast does it go?
    Central VT
    It is nice but it's no 'busa.........
    Jake
    2006 ZX-10R
    1999 Kawasaki ZRX1100
    Derry NH
    Nice bike. And as stated above, the chain is way tight. Let some length out of the adjusters.
    Aug 2011
    North Shore Ma
    I'm no expert but the chain does have about an inch of free play.. the service manual says thats good. I know sometimes manuals suck so if it should be looser what should the play be?
    Senior Member Dannyf's Avatar
    Middleboro, MA
    super tight chain is..... tight. But it does look good.
    "When there's a gap you either commit yourself as a professional racing driver that is designed to win races or you come second or you come third or come fifth, and I'm not designed to come third, fourth, or fifth. I race to win, and if you no longer go for a gap that exists, you're no longer a racing driver."
    Ayrton Senna
    loose is fast.
    Aug 2011
    North Shore Ma
    can someone tell me what the chain should have for slack? I'm just going by what the manual said. It does look like it's pulled tight in the pic but the play is there if you move it.
    Lakes
    It's a feel thing but from the photos if it was my bike I would loosen it until it just about hit the swingarm, on my 636 my chain does touch the swingarm. My old bike was a gsxr and the spec was .75-1.25 or something and that is way too tight.
    about an inch while youre sitting on it.
    if you have an inch now and it looks tight without you on it, imagine what it looks like with you on it.
    Lifer Falko's Avatar
    MoonTown
    loose is fast.
    and on the edge of out of control...
    2WT
    Adams, MA
    loose is fast.
    God I used to love that movie as a kid, now I look back and laugh.
    He'll have nice chain groves in his swingarm if he follows your advice
    1" - 1 1/2" is a good amount of slack, I'd lean more to 1 1/2".
    IMO if you have 1" of slack now being brand new, you'll end up with 1.5" shortly anyways. I'd run it as is if you're confindent you have 1" of slack.
    Sharp looking R1, still my all time favorite color combination from Yamaha
    IMO if you have 1" of slack now being brand new, you'll end up with 1.5" shortly anyways. I'd run it as is if you're hid blue headlights you have 1" of slack.
    Tighten it up so it can loosen later... thats what she said. lol. Really liking the chain though it looks really sexy, mixed with the yellow. This makes my R6 look like poop.
    Senior Member SCRLT01's Avatar
    Oct 2010
    Westford, MA
    I'm going ot be chainging out my chain and sprockets soon as well on my 2001 SV650s- being new, would anyone be able to advise me of the pros/cons of going from a 525 chain to the 520 conversion? it seems that the majority of the kits I've found include 520 chains, instead of a 525....Thoughts / suggestions / advice would be greatly appreciated!
    --Jesse
    2001 SV650s
    Quote Originally Posted by SCRLT01 View Post
    520 is cheaper and more readily available. thats why i changed over.
    a 525 chain retails for like $150 but you can get a 520 kit (chain and sprockets) for like $10 more
    Not quite. I've run all my bikes, street and race, set up similar to how Greg described and haven't seen a swingarm become eaten by the chain yet.
    The chain tightens as the suspension compresses so what was previously barely contacing the swingarm without weight now has clearance with weight.
    Apr 2008
    Boston, MA
    Some people used to say that 520s might not be quite strong enough for a liter bike. I have no idea. I guess in the future if your chain gets too loose for the adjusters you can just 86 a link.
    Do a search on the R1-forum and get back to me on that It's the bottom swingarm brace that will get chewed. I even have a small contact point in mine and I was lucky if I had 1.5" of slack.
    Also the chain tension with weight or full compression varies with each model, so what may have worked on your bike, may not on his
    Aug 2011
    North Shore Ma
    Quote Originally Posted by GNTurbo6 View Post
    I think the only way that applies would on a bike that was hitting the drag strip every week or was using nitrous or turbo. With a stock length swingarm and normal riding (not launching on slicks) i didn't hear of anyone having issues. I believe this set up is as strong as the stock stuff anyway, even though it's smaller the quality is there to back it up.
    Aug 2011
    North Shore Ma
    I doubt you would notice any difference at all other than the cost and availability. that is, unless you changed the tooth count on the sprockets. the 520 will be slightly lighter as well. go for it.
  1. HVD this afternoon 8/14 ?
    Last Post: 08-14-15, 10:18 AM
  2. this afternoon
    By schmuhl in forum Rides & Events
    Last Post: 11-04-08, 11:26 AM
  3. NY Rt6 this afternoon
    By Uncle Snake in forum Rides & Events
    Last Post: 08-15-06, 04:44 PM
  4. Sat. afternoon..
    By xvrider in forum Rides & Events
    Last Post: 10-06-05, 01:09 PM
  5. 5-13 afternoon ride
    By Graffix31 in forum Rides & Events
    Last Post: 05-13-05, 04:19 PM
