Page 2 of 2 FirstFirst 12
Results 26 to 33 of 33
Antone tow with a Tahoe/Yukon/Escalade
    Raymond NH
    Re: Antone tow with a Tahoe/Yukon/Escalade
    Coming from a truck to an SUV, you may need a weight distributing hitch to deal with the tongue weight due to generally softer rear springs on the SUV. My Durango can only handle 350 lbs of tongue weight without the WD hitch. With it, it handles 800+ lbs easily.
    Lifer LuvDog's Avatar
    Ashland, MA
    I've got an Avalanche with 22s and I've towed a 6.5' x 12' trailer with no problem.
    2003 ZX7R
    1995 916
    Nov 2004
    Boston, MA
    roughly how many pounds and what kind of trailer are you towing?
    Its a 7x12 with a dual axel...maybe 2000lbs? When fully loaded Im guessing 3500-4000 total??
    EVERYTHING is a repost
    06 749R #0047
    08 R 1200 GSA
    13 Monster EVO 1100
    Senior Member marshdrummer's Avatar
    Nov 2006
    Southington, CT
    There should be a 'trailer' switch in the automatic gear shifter. That is supposed to change the gearing for heavier loads so your tranny doesn't heat up. Watch the tranny heat gauge, too.
    live to ride seth399's Avatar
    Feb 2007
    CA
    not sure what rims/tires you have (DEUCE DEUCE) but those actually determine how much of a load you should safely carry as well. Whatever the manual says for towing/loading is on the stock load range tires/wheels. But if its a new one then they come stock with 22s right?
    Either way I hope the whole setup is on airbags and you let it drop when you get in the parking lot
    *and ya like above, turn overdrive off and watch the shifting/temp
    Just Registered Doc's Avatar
    Jericho, VT
    I bet these guys could help ya Manny.
    Antone Towing in New York, NY - YellowBot
    Posting Freak rjh200's Avatar
    Chelmsford
    You will have no problem towing that trailer. Just hook it up and go.
    JACKASS hammadown's Avatar
    Hopkinton, MA
    Quote Originally Posted by rjh200 View Post
    +1 Manny, I tow my 14X7 with my ranger, loaded with 2 bikes, gear, tire changer, other crap and its fine. Make sure your hitch is up to spec, and make sure your load is balanced well, hook up and goooooo!
    Zip Tie Alley #237
  1. Replies: 9
    Last Post: 06-30-10, 10:35 PM
  2. Ride Yukon Snowboard W/ Burton Bindings
    By Devil1 in forum For Sale
    Last Post: 06-04-10, 10:44 PM
  3. FS/FT: 2003 GMC Yukon Denali $11,999
    By Kitt in forum For Sale
    Last Post: 10-12-09, 08:37 AM
  4. How to flip a GMC Yukon
    Last Post: 08-21-07, 04:48 PM
