Results 1 to 18 of 18
Applying Decals
    Applying Decals
    DISCLAIMER: I am no expert. Use this only as a guide...
    This is for die-cut vinyl stickers, specifically 'www.nestreetriders.com' decals...
    -Gently clean the area with rubbing alcohol
    -Carefully peel off masking sheet
    -Evenly and gently apply decal
    -Once you're sure it's where you want it, apply even pressure with your fingers, being sure to work out any wrinkles
    -If you need to follow a contour, you can cut the backing sheet between the letters
    -Use a plastic squeegee to smooth out and secure decal. They can be purchased at just about any hardware store for short change
    -Gently peel off the backing sheet, using the squeegee as a sort of guide. Be sure all letters are adhering to the surface
    -Once the backing paper is off, hold it over the same decal and use the squeegee over the area again
    Again, I'm no expert. This is the method I use for applying stickers & decals, and I've yet to have one come off...
    "Offspring" wastedincome420's Avatar
    Hickvile USA
    Applying Decals
    That the same method I have always used too with great results
    Honda (RC26) VFR700
    "hey Randy, do a wheelie!!"
    Super Moderator beet's Avatar
    May 2002
    Meriden CT
    Wink mushroom um around like jay
    www.bostonmoto.com
    Forum Rules
    IWOK Prez. bigred875's Avatar
    Manvile, RI
    Applying Decals
    If you soap the target area down and having trouble getting the decal to stick use a hair dryer or heat gun along with the squeege.
    May 2002
    Meriden CT
    hair dryer yes heat gun nooooooooooo
    www.bostonmoto.com
    Forum Rules
    Manvile, RI
    Applying Decals
    if you are careful, a heat gun should not be a problem
    Innocent Angel rocker's Avatar
    Taunton, MA
    Applying Decals
    is that even with tinted windows??
    Oh also how are those on flesh?? do I have to follow those same instructions? I am leaving for florida tonight and was thinking I could advertise for NESR very well,,,
    Sorry just being obnoxious, leaving work at 1 to get all my shit together, make sure I am all set to go..
    Manvile, RI
    Applying Decals
    same rules apply to a hair dryer..you can warp plastic with a hair dryer as well. Too hot too close too long
    May 2002
    Meriden CT
    apply instructions
    anyone who needs instructions applying decals
    should not b trusted with a heat gun next 2 plastic
    www.bostonmoto.com
    Forum Rules
    Just Registered VinceF2's Avatar
    Feb 2002
    Re: apply instructions
    Beet that's one of the most coherent things I've seen you type.... it could actually be construed as an actual sentence!!! You feeling ok buddy!!!
    Manvile, RI
    good point
    Freestyle Street Rider Brian_C6's Avatar
    Jul 2003
    Windham, NH
    Applying Decals
    I applied Vinyl for 4 years as a job....
    2 pieces of tape. 1 on each side to adjust baseline height. Use baseline of text for measurement.
    2 more peices of tape in the middle (top & bottom). Peel back 1 side to middle tape. Tear 1/2 backing off (to middle tape). Spray water / soapy water. Spread squeegie from the inside of the letters up, inside letters down and continue all the way to the end. Make sure your baseline is straight. If not, soapy water will allow you to lift and re-apply.
    Now, peel back other side and remove remaining backing. Basically what you've done is split the application in half by using the middle tape. So peel back use the same technique... middle of text up, middle of text down, until you reach the end. Make sure baseline is straight. Peel top transfer tape off.
    Wah-laa!
    Lata,
    Bri
    PS. Let sit or use hair dryer. You shouldn't need much heat... just patience. 98% of bubbles are soapy water and will flatten itself in 2 hrs sitting in sun.
    May 2002
    Meriden CT
    Re: Re: apply instructions
    ha im ok mike im crazzzzzzzzzzzzzzzzzzzzzy no stupid
    www.bostonmoto.com
    Forum Rules
    Applying Decals
    Good descrip, Brian. That's pretty much the method I use with larger decals (like on my racebike), sans the soapy water. I was pretty much giving some quick instructions for the www.nestreetriders.com decals that peeps have been gobbling up lately...
    Great words of wisdom though (or lack thereof)
    Feb 2002
    Re: Re: Re: apply instructions
    Agreed... I ws just proud to finally understand Beetonics and you go and get all coherent on me!!!!!
    Northshore/Beverly, MA
    Applying Decals
    Wonder how those fancy rim stripes got put on a certain racebike......
    Gonna need a torch to get them off......
    May 2003
    Lakes Region, NH
    Applying Decals
    Can't wait to get mine in the mail so I can adhere them
    Bras cause cancer.
    Hickvile USA
    Applying Decals
    Honda (RC26) VFR700
  1. Applying number plates and numbers
    By Petorius in forum Pit Area
    Last Post: 04-26-16, 01:43 PM
  2. decals
    Last Post: 04-15-09, 03:22 PM
  3. decals?
    By mikeb in forum General Bike Related
    Last Post: 08-22-06, 11:08 AM
