Results 1 to 16 of 16
Applying number plates and numbers
    Windham NH
    I have a problem with this. You know if you've seen my bike in the last 2 years. What is the secret? I always get bubbles and creases under spots that cover lines in the bodywork.
    Feb 2007
    Re: Applying number plates and numbers
    The secret is a spray bottle with warm water and a couple drops of baby shampoo. You spray the plate wet as well as the adhesive. This makes it slideable til its perfect then you need a squeegee to smooth out the bubbles.
    Same way window tint goes on.
    Squeegee gently at first the harder to squeeze out water. Then let it dry.
    Yep a little soap and water works great, if you still get a bubble take a small pin and pop it.. Works for me..
    May 2010
    Somersworth, NH
    a hairdryer works well too. heat up the vinyl to make it a bit more plyable to help bubbles escape and creases to smooth
    Lifer Falko's Avatar
    MoonTown
    I use Mequiar's detailing spray instead of soap for applying decals. It dries a bit faster once squeegeed.
    Windham NH
    When using separate number plates and numbers, do people apply the numbers to the plate first and then apply the whole thing as one piece to the bike?
    I'd do background first, THEN apply numbers on top of it.
    I'd offer to help with advice, but, uh, you've seen my bikes. I left the clear overlay on my individual numbers for a couple rounds before I realized it was only there to apply them.
    Rocky Hill, CT
    If you are really that concerned about it, bring your bike and supplies to the RSP Racing/Pirelli garage on Thursday or Friday night and I will help you with this. It is pretty easy once you get the hang of it =)
    Lifer jasnmar's Avatar
    Mar 2012
    Chichester, NH
    I would do what Michael says. Otherwise you'll have to listen to me tell you that you should have used duct tape
    Quote Originally Posted by PainfullySlow View Post
    take him up on that and buy him dinner/alcohol. he has fucking mastered it!
    ducttape and electrical tape for numbers also works great, just saying
    Rocky Hill, CT
    Diet is set and no alcohol over the weekend so while I appreciate the gesture, it really isn't necessary.
    If for some reason you dont actually have numbers, Street and Comp sells generics or get in touch with me and I can whip some numbers up for you.
    Windham NH
    I bought a 10' roll of vinyl and I now have a 'spare' tail section, so I'll probably do a practice run with the advice above. If that fails horribly I will take you up on that offer Michael!
    10 feet of vinyl. Man, that's at least 3 or 4 crashes.
    There is clear overlay on numbers? I had no idea.
    You used to be so much fun.
    Lancaster, CA
    I will take Michael's food or alcohol Esp since if he isn't around when you stop by, I think I've been designated VP of Vinyl Application for the Garage
    Bill Cool --- CRA EX #47 --- 2023 NEMRR GTO Champion, 2020-21 LRRS LWSS Champion --- RSP Racing / TTD / MTAG-Pirelli / Woodcraft / Sportbike Track Gear / Seacoast Sport Cycle
  1. Number plates at tech
    By Philkinson in forum Pit Area
    Last Post: 05-24-17, 08:11 PM
  2. Number plates
    By Jim in forum Pit Area
    Last Post: 04-17-12, 08:52 AM
  3. ATTENTION IN THE HADDOCK! - Number Plates FYI
    By Johnny B in forum Pit Area
    Last Post: 03-20-12, 07:27 AM
  4. race bike number plates???
    By GixerJockey in forum General Bike Related
    Last Post: 05-09-08, 05:47 PM
  5. number plates?
    By dan5 in forum General Bike Related
    Last Post: 04-25-08, 09:43 PM
