Results 1 to 18 of 18
Aprilia/electrical guru's... issue w/ the T.
    Guess you can just read about it here... if you can't see the pics lemme know & I'll just re-do the whole thread over here.
    Potentially dangerous electrical issue. - ApriliaForum sponsored by AF1 Racing, inc.
    I'm gonna pick up some dielectric grease tomorrow & smear some on those contacts, put it back together & take it for a rip... hoping that'll solve my problem, but if you guys have any other theories, fire away.
    Lifer BostonSVkid's Avatar
    Dec 2005
    Re: Aprilia/electrical guru's... issue w/ the T.
    You have funny looking thumbs
    2006 Ducati Monster S2R800
    Lifer burnham's Avatar
    Apr 2006
    massachusetts
    Maybe ring it out with an ohm meter, I don't know? I have an extra switch from an '04 you're welcome to if it helps. The switch physically looks the same but has three wires coming off the side, I think it could be made to work.
    Just Registered wookie's Avatar
    Sep 2006
    San Antonio, TX
    hmmm. A male/female connector that requires a day to locate and two days to think about the best way to fix?
    2003 R6 - Track
    2000 SV650 - Street/Track
    Lifer LuvDog's Avatar
    Ashland, MA
    try a new switch.
    2003 ZX7R
    1995 916
    Dec 2005
    Near The Dragon
    from your drawn in 'dirt' it looks like the contact plate never makes it to the middle of the blue wire's contact point..
    if i am right, and if it were me, i would probably reprofile the shoulders that determines where the 'rest' location is on the movable piece of the kill switch, in hopes of getting the point of contact closer to center.
    or just replace the damned thing..
    also check the wires to and from the switch anywhere they go through a plug-style connection.
    Get out while you can
    Find your own path
    try a new switch.
    GENIUS!
    Except, why should I spend 150 bucks on a new switch when it may not even be the switch? The switch I have looks just fine & dandy now that I've cleaned it.
    Sep 2006
    San Antonio, TX
    GENIUS!
    Why spend 150 bucks on a new switch when it may not even be the switch?
    frustrated? Sorry dude, it sucks, but I usually don't see you get pissy on NESR. (or I'm not clued into the drama).
    2003 R6 - Track
    Sorry... not really pissy, just hungry & tired...
    That & the whole part about the bike not starting for a minute or two after it completely dies throws a wrench in the kill switch theory. This is why I want to get other potential solutions from people that are knowledgeable about this particular bike & electrical issues in general.
    Banned Euro trash-hole BCT748's Avatar
    Apr 2008
    Salem NH
    Sounds like you already know what you are going to do, clean it up, goop it up, slap it back together and pray it works. I'd do the same thing.
    They look like big toes
    That was the same excuse my buddy used when he was at Subway and they asked him if he wanted the six inch or the foot long and he replied "Which one's bigger?"
    Unofficial self proclaimed official NESR plumber.
    "Ah shit son, datz be a Ducati!"-Random kid in Methuen.
    Lifer markbvt's Avatar
    Georgia, VT
    If I were you I'd probably try disabling the kill switch and test-riding the bike in a safe environment to determine whether the switch is actually the problem.
    It may well be the kill switch, but it also would not surprise me to hear that the CDI has an intermittent fault. I've heard of them causing weird behavior like this on more than a few occasions; even had an intermittent CDI on one of my bikes.
    If disabling the kill switch doesn't stop the problem, see if you can swap CDI units with another bike that's not having any issues and try to duplicate the problem.
    --mark
    Ashland, MA
    GENIUS!
    well, then if you want more opinions, then get a voltmeter and start testing the shit out stuff.
    Just from the couple of pictures you posted, it looks like it may be arcing across the 2 points. That could be causing the short. Test the resistance and see if its within spec.
    And... $150 is outrageous for a kill switch. Kind of like the prices for brake light switches for my Duc... that's why, when it went bad I went to radio shack and got one for $3.
    PS... I'm not an electrician, but I did stay at at holiday inn express.
    2003 ZX7R
    1995 916
    Lifer DuncanMoto's Avatar
    A friend of mine has a 2002 RSVR and he had a similar problem. It got worse over the years and miles. He replaced the kill switch. That was not the problem. I just left him a message to get the full story.
    Ashland, MA
    I would also suspect the CDI
    2003 ZX7R
    1995 916
    My friend said. Under the right leg there's a triangular shaped vent panel. Find a 4 wire white connector. There's a blue wire in that connecter that is lose. It is a known problem with that connecter.
    Also he added if you need a switch he has one off a 2002. $50.
    Lifer akira700's Avatar
    Apr 2005
    in the city
    So from what i have read only happens at full throttle?
    Could it be either vibrations causing a bad solder point to cut out?
    or a faulty tip over safety kill switch?
    2008 Honda CBR 600RR
    Cleaned the kill switch, applied about .00001 cents worth of dielectric grease, re-assembled....
    The Ape is running like a raped... well... APE!
    I'd check the wire that was mentioned anyways, just to be sure.
  1. Electrical Issue
    By obsolete in forum Bike Maintenance
    Last Post: 03-26-12, 08:21 AM
  2. HELP: CBR Electrical issue
    By DankDirtyBird in forum General Bike Related
    Last Post: 05-26-11, 10:15 AM
  3. Electrical guru's.... blinkers are wonky.
    Last Post: 09-28-10, 04:45 PM
  4. guru lou
    By legalspeed in forum Welcome and Intro
    Last Post: 08-02-04, 08:16 AM
