Results 1 to 14 of 14
lube me up
    skilled parker getaddicted's Avatar
    Apr 2008
    Newton, MA
    lube me up
    Made you look.
    Anyways, I was wondering if anyone near the general newton area wanted to do me a favor. I really want to learn how to clean/lube my chain properly, and it would be awesome if someone could take the time to show me the ropes. I don't have any chain cleaner/chain lube of my own yet (on the to-do list) so if we could use yours that would be great, and if you want to be reimbursed for the stuff I use that's fine. I can meet you at your place, you can come to mine, we can meet at a secret rendezvous, whatever floats your boat.
    Thanks!
    Meriden, Ct
    Re: lube me up
    Spray some cleaner on a rag... hold said rag loosely around your chain... spin rear tire...
    You're chain is now clean...
    Get a can of chain lube... Spray it on the chain...
    You're chain is now lubed...
    I know... It's complicated...
    Apr 2008
    Newton, MA
    Re: lube me up
    see, you say that, but everyone says something different
    Meriden, Ct
    Re: lube me up
    Quote Originally Posted by getaddicted View Post
    It's a chain... It's not rocket science...
    Apr 2008
    Newton, MA
    Re: lube me up
    fine
    Re: lube me up
    Seriously though, the only thing I'd ad to Joel's post is to take the bike for a spin for a little bit to get the chain warmed up... helps clean it off a little.
    Member S4R_GRL's Avatar
    Apr 2008
    North West Corner of Rhody
    Re: lube me up
    I uncovered my bike last night for the first time in two weeks, only to find a
    chain that was UUUGGLLY!! I was shocked at how much rust there was on
    it. Went to MC store, bought cleaner, sprayed said cleaner on rag and
    wiped at much of chain as was exposed, move bike (DON'T ask why I didn't
    put it on the center stand ), repeat. Then followed
    up with Chain wax.
    If I can do it, you can too (b/c I'm a girly, girl)
    live to ride seth399's Avatar
    Feb 2007
    CA
    Re: lube me up
    just remember to spray the inside of the chain for the most part...ie: as your spinning the rear wheel, spray the lube at the lower section of the chain moving toward the rear sprocket (this way you get the lube on the inside of the rollers/onto sprocket teeth and it doesnt fly off right away)
    Worcester, MA
    Re: lube me up
    and i would also add to hold the chain with the rag and spin the wheel so that the part you are holding runs AWAY from the sprocket. don't want to get your digits pinched.
    and on top of that, kerosene works as a cleaner for most chains. (disclaimer: check your owners manual)
    LRRS EX #165 (formerly)
    Nov 2007
    Re: lube me up
    Like was said above, use kerosene on the chain. It does the best cleaning job, and is safe for o-ring chains. It's only dangerous if you submerge for more than 10 minutes.
    Zip-Tie Alley Racing
    LRRS/CCS #103
    Apr 2006
    Beverly, MA
    Re: lube me up
    1.) Buy this: Cycle Gear - FINISH LINE The Grunge Brush: The Grunge Brush
    2.) Submerge above item in Kerosene
    3.) Get the rear tire off the ground, put item #1 on the chain, spin tire.
    4.) Keep doing it until it looks good
    5.) Apply your favorite chain lube
    6.) Profit?
    Re: lube me up
    i did mine wednesday night. if you need to clean and wax your chain, bring your shit over & i'll put it on my stand and show you
    JACKASS hammadown's Avatar
    Hopkinton, MA
    Re: lube me up
    Quote Originally Posted by BMFR6 View Post
    Best advice...people have lost fingers spinning the wrong way...seriously!
    Im not too busy this weekend and im in waltham. go grab some kerosene (I dont have any at the moment) and i can help ya if you havent figured it out yet.
    Zip Tie Alley #237
    Manchester, NH
    Re: lube me up
    I don't even spin it when I'm cleaning it. I just give it the ol'
    If you do spin it though, clean at the top like they said. You'll end up with nubs if you don't.
  1. Best chain lube?
    By Tekime in forum Bike Maintenance
    Last Post: 09-05-18, 09:23 AM
  2. Chain lube
    Last Post: 11-08-08, 12:16 AM
  3. Chain lube?
    By zxme in forum Bike Maintenance
    Last Post: 05-08-07, 10:10 PM
  4. chain lube
    By roso in forum Bike Maintenance
    Last Post: 05-04-06, 05:06 PM
  5. Chain lube
    By NHBusa in forum General Bike Related
    Last Post: 05-19-04, 10:16 AM
