Results 1 to 25 of 41
Putting grips on
    Lifer mycirus's Avatar
    Aug 2003
    Whitinsville, MA
    Putting grips on
    Is there a trick to puting new grips on. I bought some grip glue but I heard hairspray works too. I just put the heated grip pads on the bars and just need to put the new grips on. I am just worried about getting them all the way on. I had to cut the end of them so my bar end mirrors can mount back. Any suggestions? Cant wait to use the heaters.....
    Bruce
    Lifer akira700's Avatar
    Apr 2005
    in the city
    Putting grips on
    Not that this helps now but its easier when its warm out.
    key is to use brute strength and work fast.
    I have always used the grip adhesive but sometimes if they
    are really tight I skip that and just use water.
    Or apply it later by peeling the grip back.
    Heard about hair spray but never done it.
    Does start slick then get sticky ?
    Putting grips on
    Or....
    Gas.
    Splash a little in the grip. Slip it on. Done.
    I guess all that other fancy stuff works too.
    7 bikes, all new grips, none of them slip/move/twist. Make sure the bar is clean.
    Senior Member ahtune69's Avatar
    Jun 2005
    Needham
    Putting grips on
    water with a drop of dishsoap.
    Mike
    05 636
    Green Machine
    07 Husky sm510
    Lifer imkindafkedup's Avatar
    Jan 2006
    Saugus, MA
    Putting grips on
    just use an air hose if you have it, that way when u take them off you dont need to deal with any glue or crap, and with hair spray when it dries out after a long time they can slip. Air is what I found to be best.
    Aug 2003
    Whitinsville, MA
    Putting grips on
    Got it using the dishsoap method. Worked like a champ. I used grip glue and safety wire. Hopefully they dont slip. Check it out:
    Apr 2004
    boston burbs....
    Putting grips on
    is that a pink fuzzy around the brake master cyclinder..??
    hmmmm......
    Aug 2003
    Whitinsville, MA
    Putting grips on
    It used to be red.....
    Lifer smf's Avatar
    Nov 2006
    Putting grips on
    i've always used alcohol swaps. just wipe down the bar and slip on the grip then wait once it wont move anymore saftey wire and you're done...
    Scott
    KB KB's Avatar
    Manchester NH
    Putting grips on
    You should have read the directions and used the high temp epoxy.
    LRRS/CCS EX #13
    GMD COMPUTRACK
    Aug 2003
    Whitinsville, MA
    Putting grips on
    Quote Originally Posted by rmbbikes View Post
    How come? Whats gonna happen?
    GRRRRRRRRRRRRRR! capt1014's Avatar
    Apr 2006
    Ashburnham, MA
    Putting grips on
    Best that I have found to work,
    WD-40 to get them off,
    Aqua Net to hold on the new ones, works like a charm!
    http://www.facebook.com/#/profile.ph...&id=1185417660
    Live life now!....it has an expiration date!
    Friendship is like peeing in your pants,
    Everyone can see it,
    But only you can feel the true warmth.
    Jul 2002
    Waltham
    Putting grips on
    With them safety wired there is nothing to worry about.
    Just Registered
    Is it not obvious?
    Putting grips on
    fake.
    Dec 2003
    Ma
    Putting grips on
    Those are so you can't see how black the fluids are.
    I've always used compressed air to put them on.
    Feb 2007
    Westborough
    Putting grips on
    Quote Originally Posted by capt1014 View Post
    You can apply the new ones with WD-40, and when it dries they'll be stuck on.
    Apr 2006
    Ashburnham, MA
    Putting grips on
    Quote Originally Posted by Hoser View Post
    I have found that hiar spray dries quicker and is stickier.
    Pork and Beans selltekk's Avatar
    Williston VT
    Putting grips on
    How do you safety wire them on?
    "Harley Davidson: The most efficient way to turn fuel into noise without the risk of power and handling."
    Selltekk.
    -'04 Yami YZF600R (NOT R6)
    - Uberfast Blue color
    -Two Bros. Exhaust
    -OES Sliders
    -Helibars
    -Mototeck Flushies
    -Factory Pro Shift Kit
    <a href="http://www.linkedin.com/in/davefortin" ><img src="http://www.linkedin.com/img/webpromo/btn_viewmy_160x25.gif" width="160" height="25" border="0" alt="View David Fortin's profile on LinkedIn"></a>
    Aug 2003
    Whitinsville, MA
    Putting grips on
    Quote Originally Posted by selltekk View Post
    If you look at my pics there are 2 silver wires around them. You safety wire them and cut them close to the grip and fold over the cut so it cant catch anything.
    Feb 2007
    Westborough
    Putting grips on
    Most people already have WD in the garage, plus I can never find my Aqua Net.
    Aug 2003
    Whitinsville, MA
    Putting grips on
    [QUOTE=l3uddha;352738][QUOTE=akira700;352404]
    I did that with the grip-glue stuff.
    it worked, but what a fucking mess!
    I didnt find it messy, a few thin lines of it and then wipe the excess off near the inside when you get within an inch of the end. I thought it was nice and neat.
    01cbr929rr
    Mar 2007
    In my home
    Putting grips on
    Nice grips, I have the exact same kind. I had a friend put them on for me and he used a quick setting glue that came out of a small plastic bottle with a very tapered nozzle. A few light strokes of glue-- the grips go on without a hassle, no slipping.
    KB KB's Avatar
    Manchester NH
    Putting grips on
    With the safety wire you'll be mint dude.
    LRRS/CCS EX #13
    GMD COMPUTRACK
    Williston VT
    Putting grips on
    Quote Originally Posted by mycirus View Post
    Right, but do the safety wires attach the grips to anything? It seems to me that they could still slip off under stress... With enough force I'm sure you could stiff get them off even if they are wired on...
    Selltekk.
    -Two Bros. Exhaust
    -OES Sliders
    -Helibars
    -Mototeck Flushies
    Re: Putting grips on
    Bump-
    picking up some grips today. Anyone use Progrip 699's?
    '02 F4i
  1. take-off/put-on Grips
    By JonT in forum General Bike Related
    Last Post: 05-24-10, 11:16 PM
  2. Putting together a CB200
    By JCorral in forum Welcome and Intro
    Last Post: 07-13-09, 08:42 AM
  3. Grips on R1's
    By Jim in forum Bike Maintenance
    Last Post: 02-25-09, 12:55 PM
  4. Putting a bike in the basement?
    Last Post: 01-09-03, 10:21 PM
  5. "Hot Grips" heated grips
    By interceptor in forum General Bike Related
    Last Post: 11-13-01, 04:32 PM
