Results 1 to 12 of 12
Banjo torque
    Member Damjr's Avatar
    Apr 2010
    NH
    Banjo torque
    This might qualify as maintenance, but... meh.
    The stainless lines I just put on (Goodridge) did not include torque specs for the banjo bolts and simply said "tighten." Thankfully I did some quick intarnet investimagation and got a bunch of conflicting opinions (no way ). The common theme seems to be that (as I expected) the replacement banjo bolts are aluminum as opposed to the stock steel bolts and should not be torqued to the same level.
    I've seen everything from 6 ft-lbs to 22, plus the factory 25.
    WTF? As of right now, they've been wrenched a little bit beyond finger tight. Thought I'd give bleeding a shot and see what happens, but I also wanted some local opinions so I had someone to blame when shit goes bad.
    My toys...
    02 919
    07 Daytona 675
    05 GTO
    Also, this:
    Posting Freak boloson's Avatar
    Oct 2007
    Re: Banjo torque
    5 ft- lbs i believe? its been awhile since i did mine. im sure someone else wil chime in
    Wirelessly posted (BlackBerry8530/5.0.0.508 Profile/MIDP-2.1 Configuration/CLDC-1.1 VendorID/105)
    I always use the original factory bolts and torque them to factory spec. On the rare occasion I have used aluminum bolts I have torqued them to 14 lb/ft
    High maintenance priss
    Central MA
    Re: Banjo torque
    12-16 ft/lbs. Wouldn't go any higher than that.
    Re: Banjo torque
    No fans of the German specs? Goodentite?
    #331 CBR929RE's Avatar
    Bridgewater, MA
    Re: Banjo torque
    if fluid comes out they aren't tight enough
    Andover
    Re: Banjo torque
    Man the internet kills me.
    I had the same question, I called goodridge (goodrich ) when I got my teflon brake kit. They answered the phone and told me right away. I wish I wrote it down for you, but it was a very low number, maybe 12ft-lbs max.
    Give them a call. Don't take our answer, it's an important question.
    Quote Originally Posted by Damjr View Post
    Newbie
    May 2007
    Woburn
    Re: Banjo torque
    That's what I go by ha. Tight is tight, too tight it broken.
    Wirelessly posted (BlackBerry Giggity: BlackBerry8330/4.5.0.186 Profile/MIDP-2.0 Configuration/CLDC-1.1 VendorID/104)
    Quote Originally Posted by Degsy
    You sure your rear lines have OEM bolts
    Super Moderator beet's Avatar
    May 2002
    Meriden CT
    Re: Banjo torque
    www.bostonmoto.com
    Forum Rules
    Apr 2010
    NH
    Re: Banjo torque
    Quote Originally Posted by ultraTwist View Post
    It was the weekend and I was getting impatient, but I did try.
    And I did consider using the stock bolts, but that would only work for the caliper since the new lines ran separate from the master cylinder on down, instead of splitting, so I needed the new bolt up top.
    I was able to get them bled yesterday though, so everything should be good to go.
    My toys...
    02 919
    07 Daytona 675
    05 GTO
    Also, this:
    Jan 2010
    cny
    Re: Banjo torque
    thats what I did mine to recently. put all new galfer SS lines on
  1. Double banjo for Brembo
    By 03Worc9R in forum Wanted
    Last Post: 06-17-12, 10:42 AM
  2. WTB: Banjo Bolt
    By jcbell1007 in forum Wanted
    Last Post: 04-12-11, 12:21 AM
  3. Need banjo bolt for 2004 zx-6r -- got one?
    By dhawks in forum General Bike Related
    Last Post: 09-03-10, 07:22 PM
  4. Where can i get a banjo bolt today!
    By 6 Fingered Man in forum General Bike Related
    Last Post: 05-12-10, 07:54 PM
  5. wtb: banjo bolt (suzuki) M10 x 1.25
    By Qfactor in forum For Sale
    Last Post: 05-04-07, 02:29 PM
