This might qualify as maintenance, but... meh.
The stainless lines I just put on (Goodridge) did not include torque specs for the banjo bolts and simply said "tighten." Thankfully I did some quick intarnet investimagation and got a bunch of conflicting opinions (no way). The common theme seems to be that (as I expected) the replacement banjo bolts are aluminum as opposed to the stock steel bolts and should not be torqued to the same level.
I've seen everything from 6 ft-lbs to 22, plus the factory 25.
WTF? As of right now, they've been wrenched a little bit beyond finger tight. Thought I'd give bleeding a shot and see what happens, but I also wanted some local opinions so I had someone to blame when shit goes bad.
My toys...
02 919
07 Daytona 675
05 GTO
Also, this:
5 ft- lbs i believe? its been awhile since i did mine. im sure someone else wil chime in
Wirelessly posted (BlackBerry8530/5.0.0.508 Profile/MIDP-2.1 Configuration/CLDC-1.1 VendorID/105)
I always use the original factory bolts and torque them to factory spec. On the rare occasion I have used aluminum bolts I have torqued them to 14 lb/ft
12-16 ft/lbs. Wouldn't go any higher than that.
No fans of the German specs? Goodentite?
if fluid comes out they aren't tight enough
LRRS Am #331
Man the internet kills me.
I had the same question, I called goodridge (goodrich ) when I got my teflon brake kit. They answered the phone and told me right away. I wish I wrote it down for you, but it was a very low number, maybe 12ft-lbs max.
Give them a call. Don't take our answer, it's an important question.
www.bostonmoto.com
Forum Rules
It was the weekend and I was getting impatient, but I did try.
And I did consider using the stock bolts, but that would only work for the caliper since the new lines ran separate from the master cylinder on down, instead of splitting, so I needed the new bolt up top.
I was able to get them bled yesterday though, so everything should be good to go.
My toys...
02 919
07 Daytona 675
05 GTO
Also, this:
