Results 1 to 6 of 6
Battery tender question...
    Rockin' the West Coast... Femmekat's Avatar
    Jun 2009
    Santa Barbara
    I was curious, over the entire winter while working on the bike every time the bike would get turned on to check if a turn signal was working, etc. the battery would start charging. The bike was not running, just the key was turned when sorting out the electrical nightmare that was my wiring. It would go from solid green (fully charged) to flashing green, to red (charging) in a matter of minutes. Is this normal, or is a sign of a bad battery? Doesn't seem like turning the lights on for 30 seconds should necessitate the battery to charge...
    I dunno, you dress too fashionably to be a communist
    LRRS Novice #629
    I ride/drive:
    2000 Yamaha R6
    1996 F-350 4x4 diesel truck
    and anything else with serious hp
    Lifer greenmonster's Avatar
    Aug 2003
    Re: Battery tender question...
    Hi Lauren...perhaps it may be that the charger is very sensitive to keeping the battery 100%. In other words, once you place a drain on it, no matter how short a time, or how small the drain amount, it kicks in and starts to charge. I have the same charger and it's on the battery in my cellar during winter, so I don't have any experience using it while still in my bike performing work. But it's a possibility that's whats happening in your case.
    Oh, I forgot to add, I charge double for Kawasaki's
    "My God, you're gonna have to cool me down, give me an ice block to shove in my pants or something".
    -Barbecue Lou
    That is normal....any drain on the battery should initiate the charging.
    Winter Test SAB's Avatar
    Absolutley normal. The headlights draw quite a bit when the engine is not running actually.
    55w for the headlight = 4.5A @ 12v all by itself, not to mention the fuel pump if present, and all the other bulbs/etc. So even a short check is going to draw the voltage down a touch, which triggers the tender to throw some current at the system. (Most battery tenders are .75A to 1.5A so they can't run the headlight by themselves for comparison.)
    Lifer DuncanMoto's Avatar
    Yep normal.
    If you come by we can test your cells for free.
  1. Battery Tender / Deltran lithium iron battery
    Last Post: 03-16-15, 06:00 AM
  2. Battery tender 800
    By shashankmittal in forum For Sale
    Last Post: 11-01-12, 11:58 AM
  3. Battery Tender
    By tsorfas in forum Bike Maintenance
    Last Post: 02-08-12, 10:12 PM
  4. Battery tender question
    By TTD in forum General Bike Related
    Last Post: 01-21-11, 05:23 PM
  5. Battery Tender Vs BT Jr.
    By HBerry in forum General Bike Related
    Last Post: 11-18-04, 08:42 AM
