Results 1 to 22 of 22
Battery tender question
    So my dirtbike has been sitting for 2 months. I connect the battery tender and it goes green immediately? Surely the battery can't be fully charged after that time in unheated garage?
    Tony
    Trackdays in CT, NY, and NH
    www.TonysTrackDays.com
    Re: Battery tender question
    Quote Originally Posted by 35racer View Post
    If the battery was initially deep charged properly (and don't EVER let a retailer tell you it has), it was stored fully charged and there's not a drain on it, it sure can hold a charge. My wife's ATV has sat since LAST WINTER under the same conditions as your dirty bike, battery cables still attached. I slapped the trickle charger on it this past weeked and it showed fully charged. I disconnected it, turned it over, and in sub-zero temps, it fired right up!
    Well, that would be cool if it holds that long. The previous owner set it up with a battery tender connection, so I didn't bother removing the battery (like I do with all my other bikes)
    The other bike batteries are in my heated basement... and every couple of weeks I put the charger on them... and it starts off red.
    Just seemed odd that the battery out in the cold would hold it's charge better?
    Tony
    Lifer FirstDuc-1098's Avatar
    Central Mass
    I had a snowmobile battery do the same thing, when I tried to fire up the sled, it turned over a couple times and then the battery wouldn't crank it any more, I think a cell is shot so it shows it fully charged but really isn't, new battery started sled fine
    Shit Corey says:
    Just Registered Doc's Avatar
    Jericho, VT
    Or your trickle charger is broken...
    works normally on my other batteries inside.
    guess I'll have to wait until springtime to see if the dirtbike turns over properly.
    thanks all... guess we wait and see now.
    Tony
    granite state
    mine does that sometimes. leave it on for awhile and see what happens. sometimes they seem to get a false signal. i have a battery tender jr.
    High maintenance priss
    Central MA
    Cold weather won't cause a battery to lose its charge faster than warm.
    It will if it's not fully charged. That is, a fully charged battery won't freeze...
    Quote Originally Posted by DuncanMoto View Post
    If it's a AGM battery it could be.
    Is this the "jelly" batteries?
    I don't know what I have, to be honest. I think it's the stock battery (2007 KTM450exc) which is probably just a regular old sealed motorcycle battery?
    Tony
    Lifer ZX-12R's Avatar
    Candia, NH
    Jelled electrolyte batteries are different than AGM which stands for Absorbed Glass Mat. In an AGM, a type of fiberglass mesh sits between the lead plates in the battery and the electrolyte is suspended within it. The big advantage to them is they can't spill since the glass mat is only 95% saturated. They also have an extremely low self discharge rate that averages between 1-3% per month and are highly resistant to shock and vibration which makes them good choices for all types of recreational vehicles.
    I have no idea what comes with your KTM but there is a pretty reasonable chance it's AGM since quite a few modern motorcycle batteries are set up this way.
    Mine is a Deltran and full green means it's 100% charged...
    Let's not get overly complicated here. If it's fully charged and has never been discharged, it can sit in freezing weather without discharging. Like I said, my wife's ATV hasn't been ridden since Feb. 2010 and fired right up. Proper initial deep charge, never been discharged, didn't need any charging. And it started in the sub-zero temps we had last weekend...
    Let's not get overly complicated here. If it's fully charged and has never been discharged, it can sit in freezing weather without discharging...
    I hear ya, Jay.
    It's just in all my years, this is the first battery doing this.
    Even on a really good batter... I would expect maybe the battery tender to go red for a bit (even if it's just 5 minutes) - then go green.
    Like I said, even the batteries that are fully charged and sitting in my heated basement do this after a few weeks.
    I fear that something is different because this battery is in the bike and attached to all the electrics?
    Tony
    I hear ya, Jay.
    Exact same scenario with Big Shirl's ATV, EXACT...
    Sounds good... hopefully it fires right up come spring.
    Tony
    You could fire it up right now and remove all doubt...
    Oct 2005
    Wrentham MA
    turn on something electrical on the bike like a headlight, this should immedialtely make the charger drop showing full charge... if not the battery is NBG
    Graham
    It is all winterized... don't want to put gas back into carbs.
    Tony
    Hear that noise going over your head?
    Smile Re: Battery tender question
    Yes.. it is my plane coming to pick me up and get me the hell outta here.
    Tony
  1. Battery Tender / Deltran lithium iron battery
    Last Post: 03-16-15, 06:00 AM
  2. Battery tender 800
    By shashankmittal in forum For Sale
    Last Post: 11-01-12, 11:58 AM
  3. Battery Tender
    By tsorfas in forum Bike Maintenance
    Last Post: 02-08-12, 10:12 PM
  4. Battery tender question...
    By Femmekat in forum General Bike Related
    Last Post: 04-04-10, 07:31 PM
  5. Battery Tender Vs BT Jr.
    By HBerry in forum General Bike Related
    Last Post: 11-18-04, 08:42 AM
