Results 26 to 50 of 60
Bike dying on 495S need quick advice?
    60% squid duganc1717's Avatar
    Dec 2008
    Framingham
    Re: Bike dying on 495S need quick advice?
    Fz1 Service manual
    Pages 445, 447
    Dec 2008
    Framingham
    Fz1 Service manual
    Pages 445, 447-449?
    Can't figure out how to attach the whole manual as a PDF.
    Jan 2012
    The link works.. ill try to get some time tonight to look it over
    Jan 2012
    tough diagram to read... they dont make it easy.. as far as I can tell... it could be your dash cluster, or the ECU... but it seems the ECU only controls the ground for the headlight..
    as far as I can tell, the turn signal circuit is on its own.. but there are indications that the indicators in the dash ( left turn/right turn) etc, have diodes. They also all share the same ground..
    its safe to say the ground going out of your dash is ok since other shit works..
    also.. it appears one of the right turn signals shares the same ground as the headlight..
    did you pull one of your right bulbs at a time and see what the blinker does??
    Did you check to make sure all fuses are ok?
    a bad bulb can cause the fast blinking but does not explain the dimm light in the dash..
    the only other thing you can do is start carefully inspecting the harness to make sure its not pinched anywhere which would cause a short across circuits.
    Dec 2008
    Framingham
    Thanks for taking the time to look at the wire diagram, glad I'm not the only one that struggled reading it.
    Fuses are okay
    Pulled a front turn signal bulb with same results as now, faster rate of blinking and right turn signal indicator constantly on.
    Jan 2012
    Put the right front back and pull the right rear.
    Dec 2008
    Framingham
    Here we go!
    All bulbs plugged in/ignition on:
    • instrument panel normal
    • left turn signal normal flash rate
    • right turn signal results in faster flash rate and high beam indicator flashing with turn indicator
    • no headlights
    All bulbs plugged in/bike running:
    • high beam indicator on, low beams activated
    • right turn signal indicator on all the time
    • right rear turn signal bulb on all the time
    • right turn signal activated, fast flash rate, no flashing high beam indicator
    • no headlights
    Killed engine via kill switch not ignition:
    • right turn signal rate was now normal
    • no headlights
    Removed right rear turn signal bulb/ignition on:
    • high beam indicator on, low beam activated
    • left turn signals fine
    • no headlights
    Removed both right turn signal bulbs/ignition on:
    • right turn signal indicator is off
    • activating right turn signal switch, fast flash rate, turn signal indicator is also fast
    • left side turn signals are normal
    • no headlights
    Removed both right turn signal bulbs/bike running
    • no headlights
    Removed both right turn signal bulbs/bike running:
    • unplugged left headlight bulb (right headlight already unplugged) high beam indicator shuts off
    • removed cover to left headlight bulb, all 3 terminals had ~14.08v low/high beam I'm assuming one side should be a ground?
    • no headlights
    ... have you checked your regulator/rectifier? Not to be a complete ass, but when the one on my Tiger 955 was going it shut the fuel pump off on me, dimmed the headlights, turned the rear directionals on, and flashed every idiot light on the dashboard.
    New one fixed it.
    Jan 2012
    Not a bad idea Danny500.. but I'm completely confused about the flasher continuing to flash rapidly while both right side bulbs are out... That makes no sense..
    Dec 2008
    Framingham
    I put the multi-meter on the battery with bike nut running 12.8v. I start the bike and the meter went to 13.8v, revved the bike a few times then I saw 14.4v and it stayed around 14.5v.
    Jan 2012
    so... the only thing I dont understand is if I am looking at a ground or not... its not typically the symbol for ground.. the 1st pic is what I think may be the ground for the right signals.. it actually shares the same ground as the headlights..
    the 2nd pic is the right turn and left turn grounds.. I think.. if not, it means they go to another wiring diagram somewhere... and I cant find it... it should be the ground side of the circuit however.
    the 3rd pic is the dash... the area i circled is the right side turn indicator.. i still think there is a bad ground or a short across circuits.... this could also happen in an electronic device..
    does the turn signal switch feel ok??
    Bike dying on 495S need quick advice?-ground-png
    Bike dying on 495S need quick advice?-grounds-png
    Bike dying on 495S need quick advice?-indicator-png
    Jan 2012
    im not sure if its possible.. but can you unplug the cluster and still be able to turn on the key to test the turn signals???
    im not sure if the ECU would freak out.. it looks like the connector to the dash has a dozen wires going to it..but if you can, and the signals work.. its the dash..
    so if u can, put all the light bulbs back in... unplug the dash, turn the key on and try the blinkers..
    the fact that the right blinker still flashes fast with both bulbs out indicates that there is a short after the flasher.. everything after the flasher is all the turn signals and the indicators in the dash..
    the fact that the dash is still connected and the bulbs were out but the flasher was still going indicates a short either between the switch and the dash, or the dash itself.
    Dec 2008
    Framingham
    Jan 2012
    Before you take it, try to do the dash.. I think it's that because you seem to have multiple circuits affected.. The only other thing it could be is a cut across multiple wires...
    Jan 2012
    Bikeworx
    Bikeworx
    Dec 2008
    Framingham
    Jan 2012
    Let us know!!
    Lifer golden chicken's Avatar
    Attleboro, MA
    Bikeworx has moved to a new location at 11 apsley st. Hudson.
    Dec 2008
    Framingham
    In general, with a turn signal, the light itself provides resistance to current flow (hence it produces light) and functions as a ballast. The relay that flashes the lights depends on the load of the ballast to flash the lights for the correct period of time. When the light is missing (or the bulb has burned out) it's as if the ballast isn't there, and as such the relay will flash more quicker than normal because it's under less electrical load.
    If I remove the front bulb from my VFR's turn signal, and then turn the indicators on, they will flash much faster than if both bulbs were present. Plug the bulb back in and it goes back to normal.
    Jan 2012
    So.. if they are still flashing fast.. with just the dash indicator on, then I'll assume the indicator is drawing too much current which would cause the rapid flash.. which I was trying to isolate by having everything back to normal and disconnect the dash to take it out of the picture.. I'd expect the blinkers to work..
    Yes.. if that blk wire is ground for the headlights and you grounded it and shit worked then I would argue that it's the bad ground..
    Jan 2012
    That ground was the one I circled in the picture.. it shares with the right blinkers..
    Dec 2008
    Framingham
  24. #49
    Jan 2012
    Tough question.. wiring diagrams don't always show everything that is connected.. in other words, there may be other circuits that are spliced into that ground that the signal diagram isn't showing. Best bet would be to splice a wire into the ground and ground that wire
    Dec 2008
    Framingham
  1. Replies: 42
    Last Post: 06-05-15, 05:32 PM
  2. Somebody saw you doing 135 MPH down 495S this afternoon.........
    By Suf Daddy in forum General Bike Related
    Last Post: 09-08-08, 06:28 PM
  3. Need advice quick: Fieldsheer sizing?
    By JohnnyV in forum General Bike Related
    Last Post: 12-04-07, 05:21 PM
  4. Everyone ok? (Rider down - 93S @ 495S)
    By ssg in forum General Bike Related
    Last Post: 05-06-05, 05:32 PM
