So I read I should remove my mirrors and tape all the lights. What type of tape do you use to cover the headlights and tail lights? Thanks!![]()
www.elementsofbalancemt.com
www.facebook.com/misstwisties
just regular duct tape is fine. goo-gone should remove any residue after you peel it off for the street again.
2003 Yamaha R6
1999 Yamaha YZ400
Also, pull the fuses or bulbs from the lights you'll be covering up. It'll make getting the tape & goo off MUCh easier!
and why is that? Is it that the heat from the lights will make the glue to stick even more to the plastics? The bulbs are a pain in the a$$ to put on or remove...Originally posted by Stoneman
Also, pull the fuses or bulbs from the lights you'll be covering up. It'll make getting the tape & goo off MUCh easier!![]()
I use wide electrical tape instead of duct tape. Duct tape uses a really messy goey adhesive, electrical tape comes off clean.
Yep, the heat from your headlight can cook the tape on and be a real pain in ass to remove.Originally posted by MissTwisties
and why is that? Is it that the heat from the lights will make the glue to stick even more to the plastics? The bulbs are a pain in the a$$ to put on or remove...![]()
If you know where the fuses or connectors are it's easier than opening lights and removing bulbs; just a simple disconnection of two wires before inspection, then reconnect when day is over.
